Results 1 to 3 of 3
    Veteran Member Three Rings Velox's Avatar
    Mar 30 2016
    S4
    Oranjestd
    S4 b6 misfire, help with vag codes
    So my s4 b6 just started shaking heavily and the check engine light came on.
    I got a random/multiple cylinder misfire and a cylinder 3 misfire code
    Changed cylinder 3's coil and spark plug to cylinder 2 and got a
    I got a random/multiple cylinder misfire and a cylinder 2 misfire code
    Changed the coil and spark plug to cylinder 1 and got a
    I got a random/multiple cylinder misfire and a cylinder 1 misfire code
    So in this it 100% either faulty ignition coil/ spark plug in this case?
    And why does it it also throw multiple cylinder misfire code when it clearly seems to be 1 bad coil?
    can 1 misfiring cylinder cause misfiring in the other cylinders?
    Established Member Two Rings dmanisgnarly's Avatar
    Nov 05 2014
    Supermotos & Sportbikes
    The East Coast, NC
    Coil pack. I've had great luck with advanced autos red tops for $22 with a lifetime warranty
    Sent from my SM-N930V using Tapatalk
    2005 S4//K&N/Pod filter/Carbon MAF extension/APR Carbon NACA ram-air duct/JHM intake-mani spacers/Gutted piggies/Custom Catback/034 Motorsport billet engine mounts/19” Peelers/034 Snub/Neuspeed lowering springs/JHM stage 4 Kevlar clutch/Rallyarmor mudflaps/Rocketbunny V2 front diffuser/canards/HIDs/DRLs/LEDs/trailer hitch
    02' A4 1.8T Quattro
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    Same here. Fixed my issue on my allroad.
