    Senior Member Two Rings 616_S4's Avatar
    Mar 07 2016
    2001 S4
    Grand Rapids Michigan
    Where is the oil pressure sensor on a 2001?
    I have looked everywhere and a lot of people talk about it but I hear tons of different things like under the throttle body, behind or Infront of engine, behind an intercooler hose. Different things for 2000's and 2001's.
    Can someone just tell me where it is on a 2001? I just wanna check it because I'm pretty sure it's bad.
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    It's near the oil filter/cooler. On the top side of the upper oil pan.
    Sent from my SM-G900T using Tapatalk
    Feb 05 2014
    BROOKLYN
    It's behind the ac compressor. It is kind of hard to access unless you are very knowledgeable with where everything is located on the car. If you take the ac compressor out, you will be able to see it and change it easily.
    Mar 07 2016
    2001 S4
    Never mind i found it but for kicks followed the line up the front of the engine where i found that it got loose and got caught in a belt so spliced in a new wire and ran it a different route and we are back in action!
    Mar 07 2016
    2001 S4
    i put it up on ramps and could see it, if i removed intercooler pipe id be able to get it, but didnt have to. Id encourage everyone to take a look at theirs just to make sure the line isnt too creased in the bends because its a very brittle wire. mine was pulling very tight on the sensor. and actually tore apart below the tbb as i was splicing in new wires so i got there just in time for that as well!
