Results 1 to 13 of 13
    Jun 18 2015
    DavidhogAJ
    Philippines
    Late 2016 updated B7 tune comparison thread! Who's still in business?
    I was researching available tunes and came across this comparison list: http://www.highperformanceaudi.com/audi-a4-tuning-b7
    Is this list any good? It doesn't have JHM on there as JHM came out with their tune very late for the B7 but it sounds like a very mature product... Now APR has some good numbers as an early tune and REVO looks really good as well... Most of the tunes can be done at the respective tunes local dealer's right over OBD, but some also want you to send a chip in...
    I can get JHM but my local shop does Revo, is there really much of a difference? Or, is APR safer for my car with 95k on it, yes, it has it's maintenance.
    So, 10+ years after B7 launch, what do we know now? Can we narrow it down to maybe a top 5 or ones to avoid? Any cheap eBay eastern euro tune boxes actually help?
    Veteran Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Mission Viejo, CA
    Quote Originally Posted by danbfree View Post
    JHM doesn't post any dyno numbers anywhere, don't know why. Maybe Jake will chime in and explain. I also see that the Malone tune is missing as well...
    2008 Audi B7
    2003 Ford F250 XLT
    2001 Porsche Boxster
    1999 BMW 740i M-Sport GONE
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    I think there was a very similar thread to this not too long ago.
    Jun 18 2015
    DavidhogAJ
    Philippines
    I know I tried to revive and ask for an update on an older post, so I thought I'd try my luck on a fresh start...
    Jun 18 2015
    DavidhogAJ
    Philippines
    Quote Originally Posted by mgfranz View Post
    I'm not sure why JHM doesn't post dyno numbers, everyone knows the EXACT HP can vary... I like and appreciate the ones who aren't afraid to post number for both 91 and 93 octane... Where I live we get 92 octane so I could either add a little octane booster with a 93 tune or play conservative and get a 91 tune... I guess that's almost another thread starter question...
    Jun 27 2011
    JHM has stated many times why they don't post dyno numbers. THey post 1/4 mile times (which IMO are more representative of the power the tune creates).
    This subject has been beated to death by JHM haters and supporters so many times here on AZ its really not worth going into.
    Suffice it to say, APR is a perfectly good, safe option, however pretty much any other tune out there will make more power. When I (finally) tune my B7 I'm going with JHM. The flashing situation is a bit tedious with them (buy a cable for a lot of money or try to find someone local to rent it from) however the tune is excellent.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Nov 10 2006
    B7 A4
    Detroit Michigan
    You can do revlimit
    Sent from my 831C using Tapatalk
    Veteran Member Four Rings pezgoon's Avatar
    Jul 25 2016
    new hampshire
    I'm curious to know how "unsafe" jhm's tune is
    Meaning, how much does it affect longevity. There seem to be quite a few people with 100k+ on there tunes without any major issues. One person I know has 250k on their car and it's been tuned for 180k and it still has the original clutch (this was in a thread about clutch longevity) and I'm pretty sure it was jhm but maybe not
    Eric
    2005.5 6mt A4 2.0 94k miles
    2010 Q5 3.2L 6at 160k miles
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    I think if you support the tune with proper hardware there's less "unsafe" to worry about.
    I wud never run stage 2 on oem rods, or any turbo upgrade, aswell I'd never upgrade power parts without upgrading clutches. I have bent rods, and blown clutch all on oem engine and tune. To each there own but adding power with support will usually result in opening the wallet more often.
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Quote Originally Posted by canadianA4B7 View Post
    With JHM posting 12.1 second quarter times on a completely stock motor, I would never worry about running a simple stage 2 on stock rods. I probably wouldn't even worry about it on a K04-sized turbo either, unless I was trying to get serious power out of it. As far as I know bending rods on a stock turbo is extremely rare; you should not run into that problem with an OTS tune
    2007 Porsche Cayman | 5MT
    Veteran Member Four Rings yxri's Avatar
    Dec 27 2016
    Ford Lighting
    Ohio
    Jhm stage 2 is fine. My friend has it for 60k miles and nothing has bent or broke. He also has the hpfp
    Stage 2 Banner Advertiser Two Rings Dru@JHM's Avatar
    Mar 30 2012
    Lathrop, California
    Correct.. The reasoning behind JHM not posting Dyno numbers has been beaten to death, buried, dug up and beaten more and buried over and over.
    For the record JHM chooses to give you video record and 1/4 mile times for our products instead of Dyno numbers. You ask why, the answer is simple. A Dyno realistically is only useful when comparing your car to your car and no other individual’s cars on other Dynos. There are too many variables that affect a Dyno numbers and cause you to either make more or less than the next person or advertised. Anything can affect the number, Dyno type, tire pressure, the position of the tire on the rollers, Dyno calibration, weather, what gear you are in, the list goes on.
    The 1/4 mile is really a fantastic test and proof of performance. We have been going to the track to prove performance for the last 8-10 years with our cars. You have now started to see a lot of other companies do the same in the recent years as well.
    That being said, you will sometimes hear the argument that JHM has professional drivers, the cars aren't the same yadda yadda yadda. The simple fact is you have the ability to do EXACTLY what I have done to my Avant if you want. Every part on my B7 is available with the simple click of a button or phone call to me at JHM. Having a professional or novice driver in a car doesn't take away from that cars ability to go fast. It doesn't mean the machine isn't still capable of replicating the previous pass, it just means the driver didn't have enough ability to drive the car to its potential. I am definitely not a professional driver. I have just put the time in to become very connected to my car. Only seat time and trial and error can build that connection. I can honestly say that between my Blue Avant(RIP) that went 12.5 and my White Avant I have over 350 track passes under my belt. I put the time in to learn about my car, how to launch the car and how to use the cars full potential. My first track pass in my entire life was in 2013 with my avant. It just takes practice!
    Quote Originally Posted by pezgoon View Post
    I bought my Blue Avant with 74K on it. When it was totaled it had 132,xxx on the clock and my White Avant had 84k when bought and now has 98K. The Blue Avant was a development car just like Jake's Black Sedan and went through everything from basic Stage 1-2 tuning and testing all the way to the JHM TD05H-R Big Turbo Kit. I didn’t break a single thing on either car as a result. Sure, things like spark plugs and a failed DV or outdated PCV may have needed to be replaced due to age but nothing other than the maintenance as the car requires and that is it. Obviously as we upped the power of the car we exceeded the ability of items like the stock clutch but that is to be expected when building a car for performance.
    I would never run stage 2 on oem rods, or any turbo upgrade, as well I'd never upgrade power parts without upgrading clutches. I have bent rods, and blown clutch all on oem engine and tune. To each their own but adding power with support will usually result in opening the wallet more often.
    Your situation has and will continue to confuse me. I have no idea how you bend a rod on a stock calibrated car with no mods. If the rods were really that weak Jake and I both would have done our motors in a long time ago.... Not only is my car a fully equipped BT car on a 100% stock motor, I regularly spin my motor out to and sometimes past 7500 rpms.
    Quote Originally Posted by Ashtonts View Post
    JHM Stage 1, 2, K04-R and TD05H-R are all safe for your stock motor!
    Dru
    Sales Lead & Wholesale Dealer Accounts
    (209) 968-0077 phone
    (209) 249-5255 fax
    Jul 25 2016
    new hampshire
    Awesome explanation and info thanks !
    Eric
