Results 1 to 18 of 18
    May 31 2005
    Vancouver, BC
    Installing AWE Touring Used Exhaust this weekend
    Hi,
    I own a 2013 S4 with a DSG and I bought a used AWE Touring exhaust. I am planning on doing the install this weekend but would appreciate any advice or tips.
    I'm somewhat mechanically inclined, I've done the front and rear brakes and some suspension components before but never done an exhaust.
    I'd appreciate any tips or suggestions as I'm not sure what to expect. I've read the install guide and it seems pretty straight forward.
    Thanks
    Kevin
    Veteran Member Three Rings Pared's Avatar
    Oct 28 2010
    I'm curious too. Just the exhaust, no downpipes right?
    Aug 05 2011
    LI, NY
    If just doing the cat-back it's apiece of cake really. It's all one piece so just try to have a helping hand cause it's heavy once it drops. Then you'll need someplace to store it. For the downpipes there's one nut that's hard to get to, AWE offers a special tool or just get a crows foot
    2019 RS5
    2013 Audi S5 Estoril Blue - SOLD
    Weekend Warriors - '97 Mitsubishi 3000GT VR4 / '96 Mitsubishi 3000GT VR4 Spyder
    May 31 2005
    Vancouver, BC
    Just the exhaust, I figure I'll try it without the downpipes and if the drone gets too bad then I can get them later
    Aug 05 2011
    LI, NY
    If you can under there a day before and spray the clamps with PB Blaster or the likes it'll help a lot
    2019 RS5
    Established Member Two Rings douglasjboehme's Avatar
    Jul 22 2015
    1995 Land Rover D110 2.8TDi SW, 2016 Sepang Blue 6MT S4
    Blue Bell, PA
    I think you'll need exhaust paste which you may not have since it's used. A healthy application of the stuff to seal joints is necessary.
    Sent from my Pixel C using Tapatalk
    2018 RS5 | Misano Red | All Options | AWE Touring Cat Back, BBS CH-R Nürburgring Edition Wheels
    Nov 12 2015
    Here
    Quote Originally Posted by KMoore View Post
    I did not notice much difference going from stock to AWE downpipes in terms of drone. You should consider tack welding it in place once it has settled in and you like the alignment. All those slip joints will... slip.
    Mein ist grau
    Established Member Two Rings tars9's Avatar
    Jun 15 2015
    Schaumburg/IL
    I would recommend having new clamps on hand. Mine were rusted to shit and had to be replaced. They're cheap as hell and might save yourself a good headache.
    2012 Audi B8 S4 | 6MT | Phantom Black | Kohlefaser Luft-Technik Intake l AWE Track Exhaust & Resonated Downpipes l Mertop Long-Tube Cat-Less Headers I EPL Stage II+ l Pulley Ratio 3.28 l PLM HE & Reservoir l ECS Trans and Rear Diff Mounts l CR-15 l P3 VIDI
    Oct 11 2012
    San Martin CA
    Quote Originally Posted by SportVier View Post
    Is this with manual or DSG?
    2014 S4 DSG, APR stage 2, APR DSG tune, 034 Intake, real dipstick.
    Senior Member Two Rings IceSilverS4's Avatar
    Jan 06 2014
    2012 Audi S4, 2013 Tiguan R-Line
    Blainville, QC, Canada
    Lucky you !
    Sold - 2012 Audi S4 - Ice Silver - Magma Red
    Nov 12 2015
    Here
    Quote Originally Posted by damnbiker View Post
    You have insulted me, sir! We will settle this with pistols at dawn.
    Mein ist grau
    May 31 2005
    Vancouver, BC
    It's a DSG
    2013 S4
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    Quote Originally Posted by oohnoo View Post
    This is an actually good tip, also have plenty of tools on hand..
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Jun 29 2015
    You are not going to have fun. I don't recommend the paste on install. Get it installed and aligned correctly, drive it for a week or so, make sure you still like the alignment and then carefully separate each joint to add the paste.
    All clamps loose its just a pain in the ass to assemble. I got frustrated and I used to be an auto tech.
    Mar 21 2015
    Yeah, no need for the paste. My tube from AWE is still new. Never even thought about opening it up.
    Aug 30 2014
    2023 Porsche Carrera S, Porsche Macan S, 2022 Porsche Cayenne GTS, 2013 Audi S4
    So Florida
    I would say it is an easy job myself, having changed to a AWE track exhaust in the driveway on jackstands. Use the PB Blaster on the rubber mounts to aid sliding the exhaust hangers out, spin a few wrenches, align and enjoy.
    2023 Porsche 911 Carrera 4S
    2023 Porsche Macan S
    2013 Audi S4 (son's) Konis/H&R Sport Springs, ECode sways & HL's, CR15, Alu Kreuz, H&R 10F/12R, RS4 Grill, EPL Stage 2/TCU tune, 034 intake tube/air box mod, AWE Track 102
    May 31 2005
    Vancouver, BC
    It's done!! The exhaust sounds great!!
    The only issue is that I can't get the hanger clamps on, I'm going to try soaking them in penetrating oil but I'd that doesn't work, I'll have to see if AWE sells them by themselves.
    Nov 20 2010
    Colorado
    Use vasoline it slides a whole lot better than PB blaster.
