Results 1 to 4 of 4
    Senior Member Two Rings Captain_Panic's Avatar
    May 01 2015
    B6 A4T, VS800, C6 A6, Conversion Van
    Dublin, Ohio
    Fuel Pump discussion
    I am hoping this can get some answers compiled into one thread. I am wondering under what circumstances it is worth it or necessary to get a better fuel pump. I think mine finally gave out. I have a stage 1 apr tune at 23 psi. I plan on upgrading to TT injectors and running a 93 tune soon. It doesn't seem like I am anywhere near the limit for the stock pump, but I am not sure how to gauge that.
    1. What is the limit to the factory pump? Can it handle TT injectors running that much boost? I am eventually going to run the F21 set up once my stock turbo goes. Will it hold up to that?
    2. What is a good aftermarket or factory upgrade that is plug and play?
    3. Can everyone compile their reviews of such things into this thread? I have done a good bit of digging, and hope to make a quick reference for people in my position in the future.
    02 A4 1.8t Quattro 5sp, APR stage 1, downpipe, forge splitter valve, Silicone boost hoses, K&N drop in filter, ECS vent boost guage, ECS 2.0 TSFI coil kit. Racetec FMIC. My A4 is proof that slow cars can still be fun to drive.
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    Your factory pump should handle a stage 1 tune, running the Bosch 550s, or so I'm told. You would probably have to go forth a higher capacity pump with the BT
    Sent from the 7th Galaxy.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    A stock fuel pump works just fine with the F21.
    May 01 2015
    Dublin, Ohio
    Ok awesome! So pretty much unless you are running a big turbo with large injectors, the stock pump is able to keep up. My wallet can relax now.
