My 2012 S4 has had some quirky behavior from the transmission, most of which I have chalked up to the nature of the dual clutch itself. However, this is one I can't seem to find the answer for. Sometimes when I accelerate hard while in automatic mode (it may have happened in manual mode too) in first gear, the car will hit its shift point (6800-7000) rpm and completely cut out all power. At first, I thought the problem may have been attributed to traction control kicking in and cutting the power out but after a few times of having it happen, I can never recall seeing the traction control light flash at all. It is the oddest sensation because when the power cuts, it feels like engine braking from a downshift into a high rpm, similar to what a manual would produce. I don't feel like this is normal behavior from the DSG because I have not been able to find a forum that accurately describes what is happening to me.
Has anyone else experienced this? If so, what is the likely cause and should I be concerned about it?
