Product Page
We are having a clearance sale on a small quantity of our CPS front mount radiator systems for $300 off of the retail price. Each unit is fully functional and pressure tested for leaks. The system comes with all hoses, clamps, brackets, etc to bolt directly to B8 chassis vehicles. For B8.5 chassis vehicle compatibility, 3/4th inch hose and couplers, which are purchasable at auto parts stores, must be routed from one side of the cooler to the other.
The system retailed for $999.99, and is available on clearance for $699.99.
What does it do?
The factory supercharger cooling system uses air-to-water heat exchangers to cool the hot supercharged air before it enters the engine. Hot air kills power, so cooling it is extremely important. When the supercharged air passes over the heat exchangers, heat is removed, and transferred to a coolant circuit. The hot coolant is pumped to a radiator on the front end of the vehicle where it’s chilled by air rushing through the grilles on the front end of the car, before being pumped back through the supercharger again.
Unfortunately, the factory radiator is tiny and ineffective. It does a poor job of reducing the coolant temperature at higher power levels, and needs to be upgraded. The APR Coolant Performance System (CPS) Radiator is 138% larger, and far more effective at cooling. This results in cooler coolant entering the supercharger, cooler air entering the engine, and more power for longer periods of time.
Buy one here
