Results 1 to 7 of 7
    Veteran Member Three Rings B8_Dude97's Avatar
    Sep 05 2016
    Antioch, California
    Motor noise - should I be worried?(video inside)
    Car has like a tick I guess u could say emitting from left side of motor. Looking it up people say it's the direct injection sound? But is it?
    Edit: should also add car has no idle issues and has the kick in power it should.
    https://youtu.be/IXxUkDzx4uc
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    sounds pretty normal...is it louder than normal in your opinion? what year is your car?
    Sep 05 2016
    Antioch, California
    Seems just a tad louder then I'd expect. I'm just worried it's the timing chain problem
    Sep 05 2016
    Antioch, California
    And it's a 2009
    Apr 17 2014
    MA
    sorry for not getting back to you sooner.
    that noise could be your chain/tensioner. I have a 2009, and the DI noise was louder and started to hear a rattle type noise...turns out my tensioner was at its wits end and the chain had so much slack it was ripping through the tensioner cover.
    I would at least get your tensioner checked/replaced. common issue on b8s and worth getting done before more serious damage is done to the engine.
    Sep 05 2016
    Antioch, California
    Quote Originally Posted by kdaffy View Post
    It's okay. So far it's driving fine but yea I'm getting it check Tomorow by an independent shop. Any chance u know how much it ran u to replace the tensioner?
    Apr 17 2014
    MA
    i did most of the timing components and it was a $1200 job. by just doing the tensioner you will save mainly on parts (chains, guides, etc) but labor will be pretty similar (maybe an hour or two less)
