Originally Posted by
fly300kts
D1S and D3s bulbs are similar so no real issues here
You might struggle on the projector integration
Phil
I found this which concerned me.
Currently, the factory Xenon HID market is divided into 4 bulb types (D1, D2, D3, D4) in which they are then divided into 3 other subtypes (S, R, C). The bulb types are not interchangeable. Either the physical connectors are different, or the voltage required is different. D1 and D3 types look physically identical, and D2 and D4 types looks identical. The subtypes differ slightly. S and R bulbs are not interchangeable, but the C (sometimes referred to as 'common') will replace both S and R bulbs. S bulbs are generally found in vehicles with projector housings, while R bulbs are found in the few vehicles with reflector housings. The C type bulbs can physically replace the R type bulbs, but do not have the ceramic sheild to limit the light from the bulb.
D1 and D3 bulbs: Aside from being just a bulb, these bulbs are easily distinguished by the metal box attached to the actual glass bulb itself. The metal box is an 'igniter' which is generally built as a seperate piece in D2 and D4 systems. These bulb types are much more expensive than its D2 / D4 counterparts for this reason (and also because the other bulb type is more common). There are 2 main differences between D1 and D3 bulbs. First is the voltage required to operate the bulb: D1 bulbs operate at 85V while D3 bulbs operate at 42V. Secondly, D3 bulbs are newer more environmentally friendly versions of D1 bulbs; D3 bulbs are mercury free. Because of these differences, D1 and D3 bulbs cannot be interchanged UNLESS their ballasts are replaced with the corresponding bulbs (you cannot mix components from 2 systems together).
So basically D1/D3 are the same shape, different power, as well as D2/D4 are the same shape, different power. So as long as you use the same components = no issue. So I can get D1 or D3 and be fine with matching power supplies.
The projector integration will be a bit tough but I got the spec-d headlights for crazy cheap so if I break them I won't be to upset. I still have my stock halogen(with retrofitted HID)s to replace them while I hack them up.
Are there any plug and play HID kits that can replace the D1/D3 spot? I cannot seem to find a solid answer. That would be easier for now if the HID will reflect properly (focus and length) and not glare up.
