Results 1 to 9 of 9
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    Push this thing off a cliff!!
    Among 90 other things that this car has wrong with it, I cannot get it to connect to the New York State inspection computer. No idea really where to turn.
    Tried 2 different shops and they both had the same issue. 12 volt supply is there, but wont communicate. The first shop called NYS inspection tech, confirmed that the system was running just fine. Pulled fuse for ABS module.
    The radio in the car is an OEM RNS-E, from a different model (I believe b6)
    Ideas?
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    I have heard of people installing aftermarket radios and that causing a problem with the obd2 port, something about the kline.
    Could be your rns is causing it. If you have a symphony radio try with that and see if you can connect.
    Feb 05 2008
    Waterloo NY
    I unfortunately don't have a symphony.
    What is this K line i've heard of?
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    C5 allroad 2.7 auto
    Jun 10 2013
    United States
    Just pull the RNE radio and check with a handheld scanner. Or unhook the RNS E radio. You do not need a radio installed, but the RNS E harness might be putting noise on the k line wires.
    Feb 05 2008
    Waterloo NY
    ahh, okay. Ill try that.
    FWIW the vagcom, and a generic handheld code reader connect to the car without fail or issue. So the OBD port works just fine.
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    C5 allroad 2.7 auto
    Jun 10 2013
    United States
    There are a couple of communication lines on the physical OBD port. And the inspection stations use the OBDII protocol to communicate.
    What vehicle is this for?
    Feb 05 2008
    Waterloo NY
    2005 allroad 2.7
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    C5 allroad 2.7 auto
    Sep 16 2010
    Central Wash
    I say it's user error. I have never heard of a case where VCDS WOULD comm with the car but a different system wound NOT, yet there was a problem with the car's system.
    If VCDS can talk to the ECU then I'd say it's their system or user error.
    VCDS would tell you if there was a problem with a single module, or not communicate if the K-line had a problem. They're probably missing a setting in the system..a 15 year old OBD2 car is pretty old technology; I bet their system is using a protocol for some new car or something?
    Easiest test I can think of to prove the case isn't convenient but~ have someone with another C5 head down there with you. See if their system will talk to that car and then your car.
    If it talks to the other C5 but not yours then you have a problem.
    But ...if it talks to neither car it's their problem.
    Feb 05 2008
    Waterloo NY
    hmm, alright. I have a local Indy audi/vw shop that might help me out. Ill give him a shout.
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    C5 allroad 2.7 auto
