    Dec 22 2012
    United States
    Help connecting Trans lines to new radiator ?
    I was installing a new radiator in my 2004 Audi a4 1.8t and was having a hard time getting the two aluminum trans lines to sync up and go into the radiator.
    These are the two on the passenger side that appear to press in with Orings and are held in place with an allen bolt and tab.
    Is there a trick or something I am missing here.. I have them bolted up but they stop at the Oring....
    What did I screw up...
    Thanks
    Senior Member Two Rings alimo20's Avatar
    Jan 25 2011
    Philly
    i had a near impossible time with these. check the angle in which you are putting them in, they need to be exactly flush. i even had a post about this as well.
    eventually a master mechanic friend manhandled them into their spots, but we considered using a large c-clamp type setup to push it in as well.
    my post from 4 years ago: http://www.audizine.com/forum/showth...o-the-radiator!
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    Lube the orings with a little oil or grease before assembly. You're fighting rubber on plastic traction.
    Dec 22 2012
    United States
    Thank you... I am a pretty good mechanic and engineer and generally like working on the Audi as the way it is designed... but this one got me..
    There are better ways to make this connection... Audi...
    Will go back and try again later.
    B
    Jan 25 2011
    Philly
    were you able to install the lines back?
