Results 1 to 12 of 12
    Deactivated Four Rings derek2079's Avatar
    Aug 02 2004
    UT
    Anyone have a nefmoto tuned L box file they would like to share?
    I'm kind of embarrassed to ask but does anyone have a tuned L box file they would share with me? Nefmoto is to advanced for me to create my own tuned file with.
    Apr 07 2011
    Home of the mighty beaver
    Quote Originally Posted by derek2079 View Post
    dont feel bad. im an actual genius and i just threw my hands up at that thing and said fuck it.
    Aug 02 2004
    UT
    Sounds about right
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Do you know how to log?
    At the very least you should learn fuel and timing tables.
    Just taking a file someone sends you randomly, flashing it to your car, and running it could end up very badly.
    Aug 02 2004
    UT
    No idea.
    Nov 16 2014
    ovid ny
    Dont Worry about L box a box. You want to flash it to a m box . That is what nefmoto uses as far .xdf's. aka definition files. They have some easy to use stage 1 & 2 .xdf's there about fool proof. But when you tune with nefmoto it needs to be specific to that car. You "tune" your car with the logs from like me7logger. And then use ecuxplot to look and compare them, then tuner pro to make changes the .bin and nefmoto just to flash it back to the ecu.
    But be happy you asked on here and nefmoto.
    Aug 02 2004
    UT
    So are you saying I can use a M box tune even though the M box is for a manual?
    Aug 02 2004
    UT
    Well I flashed it to a tuned m box file and its not working and I just sat in my car for hours trying to flash it back with zero success. Anyone have any suggestions?
    Nov 02 2014
    Winchester, VA
    Did you modify the file?
    If so, checksum.
    - - - Updated - - -
    Even if you didn't modify, you should run a checker.
    Aug 02 2004
    UT
    why should i run a checker? and how do i run one? Im trying to flash it over to a stock file right now.
    Nov 02 2014
    Winchester, VA
    You need to read this at a minimum before doing anything else, or pay someone who knows what they are doing.
    Nov 02 2014
    Winchester, VA
