This is killing me having to post this. But I'm pretty frustrated.
2003 1.8t
I'm getting several codes that happened put of nowhere.
01 Engine Control Module 1
System description: 1.8L R4/5VT G
Software version: 0003
Hardware number: 8E0909518AF
Coding: 0016701
Trouble codes:
P1118 - Bank1, sensor2, heater circuit Open circuit No signal/communication
static
P1289 - Turbocharger recirculation valve Short circuit to ground Lower limit not reached
static
P1114 - Bank 1, sensor 2 Internal resistance too high No signal/communication
static
P1116 - Bank1, sensor1, heater circuit Open circuit No signal/communication
static
P0102 - Mass or Volume Air Flow Circ. Low Input Lower limit not reached
static
In short. I've replaced the maf with three working units and VCDS still shows 0.00 reading on Group 3 Block 4. I checked the voltage on pin 2 and I'm only getting 3.15V to the maf with the key turned on. I replaced the pigtail harness on the maf and searched for a cut in the harness and still no bueno. Car runs good but I can tell my fueling is off. I have also replaced the bank 1 o2 and nothing changed. What the french. Toast. Thanks everyone.
