Results 1 to 11 of 11
    Established Member Two Rings Wyd's Avatar
    Jun 29 2016
    WA
    Question looking for confidence- timing chain job
    Will be replacing my timing chains and guides this weekend and im looking for any tips for a boost in confidence
    Any thing a should look out for or any diy's out there i can go over?
    Any info at all is appreciated!
    -Gage
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by Wyd View Post
    -Gage
    -take your time
    -label everything
    -be patient
    -organize your space
    -do not re-use TTY(stretch) bolts
    -use a bentley manual for the timing part of the job(torque values are critical)
    -check cam timing at least twice before closing the covers
    -beer after work only, gotta have full focus
    worst thing that could happen would be setting the timing with the chains loose or screwing up a mechanical adjuster assembly, which would result in timing codes at initial startup(means you're starting the job all over again)
    btw , are you mechanically inclined ?
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    when you insert the cam alignment tools...cyl8 (EIGHT) will be at TDC...dont freak out. It just is what it is lol.
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    Do i need loctite for the timing/ guides components?
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by kevinye77137 View Post
    no. They're low torque and the guides just slide on and off, they're NOT bolted.
    Veteran Member Four Rings gcoy's Avatar
    Apr 06 2009
    2005 B6 S4 6mt Avant & 2001 B5 S4 6mt Avant (Sold) & 2007 VW Passat 3.6 4Mo wagon
    Boise Id
    Quote Originally Posted by jakeoboy67 View Post
    -take your time
    -label everything
    -be patient
    Great advice
    Jun 29 2016
    WA
    Am mechanically inclined. Also I already have the motor apart staring at my broken guides lol. Rented tools and I'm waiting for them in the mail. To my understanding there's a Bentley manual link floating around (hopefully)
    Also do I need a breaker for the chains?
    Is there time by marks? (Haven't sat and looked at the motor too much over the last 2 weeks it's been apart) it's a headache to look at 😂
    Jul 15 2015
    Rochester NY
    I second "label everything", including nuts and bolts, and add get all your gaskets, seals, etc. lined up in advance. Also, do mark the timing chains so you can put them back on the right way round - I missed that step and so am fitting new ones...
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    I would recommend getting the Bentley, idk about a link but you can purchase from ECS or other sites for <$100.
    Here is my thread from last year if it helps; mainly don't forget to change all the little gaskets on the backside of the tensioners as they don't all come with the timing kits (I know my JHM kit did not have them all).
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by badger. View Post
    I have replaced the lower tensioner's o-ring with one from a generic o-ring kit, since it wasn't in the jhm timing kit.
    Apr 06 2009
    Boise Id
    badger's thread has a lot of great info.
    You do not break the chains they come off when you remove the sprockets. It is intimidating until you dive into it. You can do it, just get a manual
    Here was part of my journey
    http://www.audizine.com/forum/showth...light=warriors
