Results 1 to 12 of 12
    May 22 2008
    Vancouver
    2013 A4 manual transmission - warranty help
    Hey all, new to the community! Just bought a second-hand 2013 A4 a few months ago. Looking for some help in dealing with the warranty and the dealership.
    My car is still covered under the original 3 year warranty. It's only got around 12,000 miles on it.
    I've read some posts here where some people have had manual transmission problems similar to mine and were successful in claiming it through warranty. I brought my car into my dealership and asked them to check out my transmission issues (clutch shudders when engaging in first gear). Before they even looked at my car, the service advisor said that the transmission is a wear item, so it's not covered under warranty.
    I tried to explain that my car only had 12,000 miles on it so it shouldn't even be close to the point where the transmission should normally be worn down. The advisor said (a little arrogantly, I might add) that it doesn't matter, even if the car only had 1,200 miles or 120 miles, it still wouldn't be covered because it's a wear item. I tried debating the issue a bit more, but he wasn't budging on his stance.
    I ended up just leaving because he wanted to charge me just to inspect the transmission because out-of-warranty inspections also would cost me money.
    My question is - should I even bother arguing further? Am I stuck having to pay for the repair myself?
    May 27 2016
    Maine
    Welcome to Audi service! Not an unusual experience. The local Audi service dept here is terrible. Luckily I have an awesome Audi shop to do my work.
    He is likely referring to the clutch which is a wear item and can be badly abused in short time. I would search these forums for the word shudder to see if anyone else has had this experience.
    Also cannot hurt to call AoA to see what can be done.
    Tim R.
    2010 A4q MT Premium+, Brilliant Black
    Injen intake
    Eiback Sportline Springs
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Quote Originally Posted by Tim R. View Post
    +1
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    It isn't uncommon, based on browsing the forum since I got my 6MT. This specific transmission seems a little more finicky than other manuals I've owned and driven, and mine shuddered occasionally when I was new to it but that went away as I got used to the car and it got used to my driving style.
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Veteran Member Four Rings AllroadCorbin's Avatar
    Jan 15 2014
    B5 S4 (sold) | Saab 9-3 | B8.5 Allroad (sold) |B9 Allroad (totaled) | LB7 Duramax
    Boston, MA
    Quote Originally Posted by Project Quattro View Post
    If you want finicky try driving a Saab MT haha
    B8.5 Allroad | APR | CTS K04 - SOLD
    B9 Allroad
    B5 S4 | GermanElite | SRM K24
    '11 Mercedes C300
    '05 Saab 9-3
    '92 Saab 900s
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    i would report that dealership to AoA.
    your cars still under factory warranty.
    they didnt even bother checking your cars VIN?? thats ridiculous.
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Senior Member Three Rings petraman's Avatar
    Apr 26 2016
    Columbus, OH
    Blip the throttle more and let the clutch out quicker. Fixed the shudder for me. Still rears its head from time to time, but it's nowhere near as apparent.
    AoA gave me the same shit... Even though I noticed it the first day I brought the car home. Certified my ass...
    Jan 03 2013
    Baltimore
    Thats some terrible service. I had mine in (2010) for the grainy/squeaky clutch pedal which requires the trans to be dropped to replace the pivot arm and a few other things associated with the clutch. There is a TSB for it and mine was covered under the factory warranty. It did take a few visits to the dealer to finally get them to diagnose it right. Good luck, try another dealer.
    Apr 26 2016
    Columbus, OH
    This issue feels more like a warped flywheel than a grainy feeling. Unlike a warped flywheel, it comes and goes
    May 22 2008
    Vancouver
    Thanks everyone for the advice. I ended up calling Audi of Canada (I'm Canadian :)
    I got a similar response from them as I got from the dealership - transmission (not just the clutch, I asked) is a wearable part, so it's not covered no matter how little mileage, unless it's proven that it was caused by a defect. I asked how I can prove it's a defect, and their response was for transmissions, there's no way to tell for sure unless it's taken apart. So essentially, the dealership could take the transmission apart and if they found a defect in any of the parts, they would cover everything. If no defect was found, I would have to pay for everything.
    Sounds like an expensive gamble to me...
    I guess I'm stuck with what I got until the tranny completely goes. Not a good start to owning this car :(
    Mar 17 2014
    Los Angeles, CA
    That's bullsh*t. Per Audi's website, here is what has been listed under covered items:
    Manual transmission - gearshift lever, gearshift block, gearshift cable, transmission housing, transmission mounts, internal shift rods, internal shift forks, main shaft, all internal bearings and bushings, all synchronizers, all gear sets.
    Doesn't list clutch, but that makes sense, as you could wear one out fast if you don't know what you're doing.
    instagram
    Established Member Two Rings rob_23's Avatar
    Aug 20 2013
    Vancouver BC
    I had my clutch and transmission replaced under warranty free of charge.
    They put a scope in and inspected the clutch disc for wear. There was none.
    I then had them drain the transmission fluid and it had metal shavings in it.
    They concluded that the gear forks must be causing some issues because the clutch disk was fine and not contributing to the metal shavings that were found.
    This course of action might help you prove a manufacturer defect.
    2010 a4 Premium | 6 MT | Meteor Grey Pearl | Tinted | Rear lip spoiler | CF interior trim | LED plate lights | RS4 Grille | H&R OE Sport Springs | Koni Yellows | aFe | 034 | Apikol
