Currently in the shop we have two TiAL 770 cars being Built.
We hinted in the first thread that we would be showing off the second build fairly shortly and here it is.
This B5 S4 is getting the whole 9 yards, TiAL 770s turbos, 3.0L built engine and Refreshed transmission with JHM Parts and a whole lot more.
Engine Modifications
3.0L Stroker Crank
Mahle Motorsports Custom Forged Pistons
Ferrea +1mm Intake and Exhaust valves
Integrated Engineering Spring/Retainer kits
Integrated Engineering 2.0 coil conversion
Integrated Engineering Connecting rods rifle drilled
Integrated Engineering FSI Coil Conversion with R8 coils
Custom -12an Valve Covers for Custom PCV system
Custom v-Band Bi-Pipe
Calico coated Rod and Main Bearings
Aqua Mist Water Methanol Injection kit with custom hidden Tank Mount
ARP Head and Main studs
RS4 throttle body
TiAL 770 Turbo Kit
034 TiAL 770 down pipes
034 Motorsport 3.5" Single Exhaust System
034 silicone breather hose kit
EPL GT fueling kit
Custom Fuel System with Inline Filter and Dual Pumps
Custom Modified RS4 Intake Manifold with modified plenum
Fluidampr crank pulley
Apikol side mount inter cooler with water meth bungs
Custom 4" Intake
Drivetrain
JHM Shifter Trio
Driveshaft Shop 1000HP axles upgrade
Clutch Masters 850 series twin disk
Clutch Masters Lightweight steel flywheel
JHM 6-speed rebuild kit w/ updated 1-2 collar
JHM 4:1 Center diff upgrade
034 Motorsport Billet Aluminum Differential Carrier
034 Motorsport Motorsport Mounts - Track Density
Apikol rear differential mount
APR snub mount
That is all for now stay tuned for more information and progress on this build.
If you would like to know more either call
203-483-6100
[email protected]
Or, check it out online
http://vag.excelerateperformance.com/products?bid=13716
Check Us Out on Social Media!
