Results 1 to 8 of 8
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    Best Bang for the Buck Rotors & Pads
    I can get some Stoptech sport slotted rotors 288 rear 320 front for $325 shipped along with Hawk HPS for another ~ $150 . Total comes out to $475. Are there any other alternatives that can provide the same or better value at a better price?
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Dec 01 2011
    Akebono pads, or the Stoptech/Centric pads are good too, might be a bit cheaper, closer to $100 for the set.
    as for the rotors, the best bang for your buck would be to get normal rotors (not slotted or drilled). they do look better but they also they eat through the brake pads much quicker.
    IG @theshawon
    May 20 2010
    I usually go for the Centric high carbon discs and posi-quiet pads. Also you can find several threads that discuss this with some searching
    Jun 18 2015
    DavidhogAJ
    Philippines
    Quote Originally Posted by Liquid Smoke View Post
    I agree... I think our stock rotors are actually quite good so slotted and cross drilled actually reduces surface area and does eat pads quicker. They do look good, but the cross-drilled/slotted stuff is only for hard core racing where they need quicker cooling to prevent brake fade and use very large size rotors to compensate for the lost surface area.
    Veteran Member Three Rings seandon_792's Avatar
    Aug 12 2015
    Waldorf, MD, US
    Got a full set of slotted cross drilled rotors with pads all around last winter for a little under $400 from rock auto.
    Jan 24 2013
    Chicago
    Ill probably go with the high carbon blanks from centric and with a higher performing pad like hawk hps. Thanks for the input everyone.
    How is the dust on the posi-quiet pad?
    Sent from my SM-G920P using Tapatalk
    Dec 01 2011
    if you're tracking the car or want it for the looks, if you don't mind less long term reliability and lasting, then go for the slotted/drilled. but for a normal daily driver, and you want the rotors and pads lasting as long as possible, go for the normal setup. i went through the same dilemma, i really liked the drilled/slotted look but in the end figured it wasn't worth it just for the looks i'd rather just have reliable and longer lasting brakes and not have to do another brake job that early.
    IG @theshawon
    May 20 2010
    Dust isn't bad at all on the ceramics I have. On the normal ones, they dust less than OEM but it is noticeable.
