Results 1 to 11 of 11
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    need to replace axles and cv boots, part numbers?
    So I try looking for part numbers for the front l/r axles B6 S4, cannot seem to find the correct ones. tried calling the local Audi and get put on hold for ever..
    I have a friend who has a l/r for an A4, will those work?
    going to be also be changing my front struts in the process while adding B5 perches, and preferences? this is a daily driver, not a track car.
    May 18 2012
    2005 S4
    Portland, OR
    A4 axles are different. Is the car manual or auto? The axles are different.
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    They are thiner so if you go crazy you might snap them but they will work as long as they are same transmission
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Oct 05 2015
    Billings, MT
    they were both for automatic, mine is a tip. I would rather have the correct ones but both of my boots are shot to hell, I don't notice any issue driving though, I guess they have been this way for a while now.
    Derp day for me, I should have looked on JHM...
    https://jhmotorsports.com/shop/catal...tip-p-721.html
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    raxles.com also has them
    I don't have the part # handy right now for the axles themselves - but did you look on your current ones? IIRC there was a sticker or stamp on the OEM ones I pulled off that had the info.
    I do know the bolts are N90441103 (I needed to purchase a few of that were stripped)
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Oct 05 2015
    Billings, MT
    Thanks Badger, just emailed them for a quote.
    Jan 17 2014
    New Jersey
    you can also call napa or find a place that rebuilds them. here in NJ there is a shop that does it for 95$ with 1 year warranty.
    Insta: luccamentone
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by Lucca M View Post
    That is a great idea, Thanks Lucca! BTW, can you give me some info on your wheel setup?
    Jan 17 2014
    New Jersey
    Actually i have one axle i could sell you but probably shipping will be a bitch. It was rebuilded 2k before i did trans swap. Second axle would need new boot since i ripped it while pulling the engine but it was also rebuilded.
    And my wheels are 9.5 with 8mm spacer front and 10,5 rear no spacer but dont remember the et right now lol. I think 49 front and 42 rear
    Insta: luccamentone
    Established Member Two Rings dmanisgnarly's Avatar
    Nov 05 2014
    Supermotos & Sportbikes
    The East Coast, NC
    Raxles!! They're indestructible
    Sent from my SM-N930V using Tapatalk
    2005 S4//K&N/Pod filter/Carbon MAF extension/APR Carbon NACA ram-air duct/JHM intake-mani spacers/Gutted piggies/Custom Catback/034 Motorsport billet engine mounts/19” Peelers/034 Snub/Neuspeed lowering springs/JHM stage 4 Kevlar clutch/Rallyarmor mudflaps/Rocketbunny V2 front diffuser/canards/HIDs/DRLs/LEDs/trailer hitch
    02' A4 1.8T Quattro
    Oct 05 2015
    Billings, MT
    Just had a baby and wife isn't working right now. Low on funds. Raxles will have to be a different time. Right now i just need to replace them.
