Originally Posted by
Lion Heart
Hey roboto_1337
Thanks for that. Was yours an auto also?
When you say drivers/passenger side - UK or USA?
Also, what tool combo did you use? Could you attack any straight-on, or did you have to use one/two universal swivels to get odd angles?
And the million dollar question: are they harder or easier to get those nuts back on than they are to remove??
No it's 6M, I didnt' have to drop the sub-frame.
Really I just played with different swivels/wobble extensions drive sizes long/short sockets until I found something I could get a good position/torque with. 5 of 6 were easy to get back on... the top nut on the driver side was the biggest pain... also when you put the axle guards back on I only did the 2 easy ones, so future work is easier.
a couple of things that i learned will make it go quicker... make sure you loosen the rear O2 sensors first, then drop the cat-back, and take them off the mid/rear hangers otherwise they'll stretch and the hanger with ting against the driveshaft... very annoying.
also the passenger side harness for the O2 sensors in the engine bay are easier to work with if you take them off and line them back up after.... driver side it didn't make much of a difference.
when pulling the downpipes out you also have to rotate them to work the bends around the axles/transmission.
I'm in Canada, so North American Left hand drive vehicle.
gutting them is easy I just used a 3/4"x 16" long spade bit and some long needle nose pliers drilled a bunch of holes and it comes right out.
*Edit* the nut that you feel is squished against something is a heat sheild for the exhaust manifold I beilieve, that's what makes the top nut an absolute bitch to get at, If I can remember a I got it off with an impact swivel socket and 2 extensions.. I wanna say 3" and 12" but can't remmeber for cetain.
Also don't quote me, as you may not have to do this, but I believe with the Tip you have to lower the sub-frame a little bit by using a jack and a wood block to give yourself a bit more room
