Results 1 to 9 of 9
    Veteran Member Three Rings khj677turbo's Avatar
    Dec 25 2007
    Tampa
    APR Exhaust Too Loud
    I bought a single outlet APR turbo back exhaust used on here a few months ago and have been running it with the APR Stg 2 flash. The sound is pretty awesome, quiet while cruising, loud when I jump on it. That said, I want to tone it down and go back to more of the sleeper approach. I'd like to keep the performance benefits of the exhaust but remove the noise. Any thoughts? Are there performance mufflers out there with a 2.5 in diameter (have to double check this number) without the noise? I could do custom from the mid back if that were the case.. or should I be looking at a new exhaust entirely?
    TIA
    Current: 13 A4 P+ Sport, K04 etc, 18 SQ5
    Gone: 04 A4 1.8t USP 6-speed Avant
    Gone: 00 A4 1.8t K04'd
    Mar 11 2012
    Audi A5
    Ventura, CA
    sell me the catback, but your stock back on and keep the HFC and downpipe for performance. =P
    2011 A5 2.0T//Ice Silver Metallic//30% Tint//RS5 Replica Grille//LED Interior Lighting//APR Carbonio Cold Air Intake, HFC, Downpipe, and Stage 1 ECU Tune//Carbon Fiber Mirror Caps//Lamin-x tailights//H&R Swaybars and Street Performance Coilovers
    Jan 10 2007
    VA
    If you want the performance with minimal noise, all you need is the HFC + downpipe mated to the OEM exhaust.
    If you want to keep the APR exhaust but make it quieter, you can weld in an additional center muffler or resonator with a straight through design.
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Dec 25 2007
    Tampa
    Quote Originally Posted by b6onboost View Post
    Could I replace the current resonator with the one A4 Centaur linked and get the same result?
    Jan 10 2007
    VA
    Quote Originally Posted by khj677turbo View Post
    Unsure. It may do nothing, make it a little better or a little worse. There's no way to know. But adding it in line with the existing setup will definitely quiet things more.
    Jun 05 2009
    Scottsdale Arizona
    ^ Yea worked perfect for the drone I was having at 2200-2500 RPM's.
    It was installed inline with the other bottle resonators
    Registered User Three Rings MagnaFlow's Avatar
    Jan 26 2015
    Oceanside, CA
    We would agree; adding another muffler into the system will work with the existing one to help cut down the volume.
    Turbo, if you would like help choosing one for your exhaust, feel free to shoot us a PM!
    Jun 05 2009
    Scottsdale Arizona
    Magnaflow is good stuff!!
