Results 1 to 37 of 37
    Nov 25 2014
    2002 Audi A4 3.0
    Columbus, IN
    3.0 Timing Belt Questions
    Hi All, Sorry if this has been answered before but I did some search and there just isnt much about the 3.0. Im gearing up to replace my timing and serpentine belts on my A4. It is an 02 with 85k on it, and as far as i know they havent been replaced. My question is what should I replace when I do service. I am already planning on replacing the valve cover gaskets. What else do you guys recommend I replace? I just bought a house so I am trying to avoid buying a $500 kit if I dont need it.
    Thanks in advanced
    Mar 21 2016
    69 Nova
    California
    As much internal "while you're in there" stuff as possible, just to save yourself from having to tear the front apart again. When I did my timing belt, I did the timing belt, tensioner and idlers, serpentine belt, serpentine tensioner and water pump. I also did spark plugs just because I didn't know how old they were (and it was basically a tune-up/timing belt job for me), but I didn't do valve cover gaskets because mine weren't leaking and looked good.
    I may get flak for this, but I didn't feel like spending $500+ either, so I got all my stuff from RockAuto. Everything looked like quality parts and I haven't had any issues since.
    12 S4 Quattro 6 Speed
    04 A4 3.0 Quattro 6 Speed
    69 Nova with a bunch of stuffs
    19 Sportster 883
    Feb 10 2011
    MI
    Same here. The rock auto conti kit with water pump is quality parts with metal water pump and you cant beat the price.
    Sent from my SM-N910T using Tapatalk
    2004 Audi A4 Quattro 3.0 6sp Ultrasport
    2002 Audi A4 Quattro sport "development" car
    2005 Passat TDI Wagon 6 m/t
    1996 Audi A4 Quattro 2.8 (daughter)
    And all the Ford trucks you could want
    Aug 27 2013
    Philly
    That continental kit is fine, but the problem is, it doesnt come with all the other parts that should be replaced. Sure the $500 kit is pricey, but it comes with EVERYTHING you need. If you have even one leaking seal (you have 5 to worry about 4 cam and 1 crank) the kit will pay for itself. If you're not about buying the $500 kit, you're still going to need the Conti kit, a new serp belt (i recommend a new serp tensioner too), valve cover gaskets (not replacing these is asinine and only asking for problems later on, sorry), thermostat, and new coolant.
    I'm sure I'm missing a few things, but the kit really does cover everything that should be replaced when doing the job. This job is not fun to do and I know I would rather fork over an extra $150-200 now than have the car leave me stranded in 6 months because I cheaped out and didnt want to change the thermostat or something.
    Jan 09 2012
    MA
    You are also going to need to buy, rent or borrow the cam lock tools.
    Apr 07 2011
    This should help along the way. Click
    Mar 21 2016
    69 Nova
    California
    Quote Originally Posted by SJorge3442 View Post
    Thermostat and coolant are something I do with every timing belt change. I didn't mention them because I'm not sure if others are the same way.
    In regards to the cam seals, crank seals, and valve cover gaskets...eh. I did a lot of searching and nobody really ever talked about doing them during a timing belt job. Nor did anyone talk about leaks from not doing them. So I didn't do any of them and I don't regret it.
    19 Sportster 883
    Aug 27 2013
    Philly
    Quote Originally Posted by DarkoNova View Post
    Yeah I didnt have to use any of the seals either, but not everyone is that lucky. Once you figure in another $50-75 for the thermostat and then $50 or so for the coolant, you're getting really close to the cost of the Blauparts kit.
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    So true, I did everything but the seals! Now my cam shaft seals are leaking. So much work just to get to the seals. Sh!T
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Jul 28 2014
    SACRAMENTO
    Quote Originally Posted by Fouad1013 View Post
    Thanks in advanced
    Holy cow 85K on 14 year old car! Ill be turning 200K by next week! So jealous...
    04 B6 A4 USP 2.7t
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    I have a post on here somewhere that lists all the parts I had changed at the dealer performed timing belt service. It corresponds more or less to the kids that are in the $5-600 range. The crank seal is the only thing I don't think has ever been replaced as it is more of a don't touch unless leaking seal IMO.
    Sent from my DROID Turbo 2
    Sep 08 2016
    Grover Beach, CA
    Please please dont drive it if possible. I just picked up an 03 A4 with 85k miles. Drove it for a few weeks knowing the timing belt had to be done. Finally getting around to it this week/weekend and got a view of the belt. Its cracking like crazy and i got lucky it didnt break in the few weeks i drove it after i bought it.
    Anyways enough scaring you. here is a great procedure for changing out the timing belt and water pump. http://www.audiworld.com/tech/eng110.shtml
    Hopefully it helps!
    Im changing the timing and serp belt. Water pump, tb tensioner and idler pulleys as well the the tension mechanism. Also changing the serp tensioner. Valve cover gaskets will be changed as well along with new fans for the radiator and snub mount damper. I dont have the o-rings for the caps on the cam pulleys but i think that i should be able to find them if they need to be replaced(assuming they are standard o-rings).
    Good luck on the job, cheers.
    -Erik
    Veteran Member Three Rings pablolizarraga's Avatar
    Jul 18 2014
    "Hers": SQ5 His: 1966 Ford Mustang Coupe, 1965 Ford Mustang Fastback
    Los Angeles, CA
    I've been compiling any info I can in preparation for this behemoth of a maintenance procedure and came across this DIY video for rent $3.
    Has anyone rented this video?
    Good luck!
    Aug 27 2013
    Philly
    Quote Originally Posted by ErikG View Post
    Hopefully it helps!
    -Erik
    Quote Originally Posted by pablolizarraga View Post
    Good luck!
    The files shared above contain everything that you need. This forum is a wealth of knowledge which will also help you out, but for $3, it probably wouldn't hurt to have that video
    Sent from my Nexus 6 using Tapatalk
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    Here's another video. Haven't watched the whole thing but the trailer looks less flashy with more info.
    Audi A4 3.0L V6 Timing Belt Replacement Video- Engine Code AVK
    AZ member diuvic found that. Posted in this thread:
    Crank-Seal-Replacement_3-0L-AVK-Oil-Leak-Madness
    Nov 25 2014
    2002 Audi A4 3.0
    Columbus, IN
    Thanks for all the information guys. I think I'm going to do the belts, rollers, tensioners, water pump, thermostat, serpentine belt, Valve cover gaskets, and the accessory rollers. There is a European Auto Parts store in town that can get almost any part next day. Its not gonna be for another couple of weeks till I am able to do the job, but I will keep you guys updated. I still need to figure out where to buy the parts. Does anyone have any recommendations?
    Feb 03 2009
    Florida
    Blau Parts has three timing kits available for the 3.0: Base, Enhanced, Enhanced+
    $260
    BLAU INA Pre-assembled Base Kit Includes:
    1 INA Gates Timing Belt
    1 NTN Timing Belt Tensioner w/ Genuine Hardware
    1 NTN Timing Belt Hydraulic Tensioning Damper w/ Genuine Hardware
    1 INA Timing Belt Tensioner Eccentric Idler w/ Genuine Hardware
    1 INA Timing Belt Tensioner Idler w/ Genuine Hardware
    1 INA Timing Belt Service Interval Sticker
    $505
    Base Kit plus Enhanced Additions:
    1 Graf Water Pump w/ Metal Impeller, Heavy Duty Pulley, and Gasket (Updated Mfg.)
    1 Mahle Original Thermostat Assembly With Housing & O-Ring
    1 Flennor Gates Serpentine Belt
    1 Viton Front Crank Seal
    4 Camshaft Seals
    4 Camshaft Sprocket O-ring Seals w/ Circlips
    2 Valve Cover Gaskets
    1 Front Motor Mount
    1 Thread Locking Compound
    1 Anti Seize Compound
    Blauparts Detailed Step-by-Step Audi A4 Timing Belt Instructions
    Numerous pages and images of detailed step-by-step guidelines, including front bumper removal.
    $534
    Base Kit plus Enhanced+ Additions:
    4 Camshaft Seals
    1 Front Motor Mount
    6 Liters German Ravenol G12 Plus Antifreeze (4 - 1.5L Bottles)
    Appropriate amount for complete cooling system flush.
    I have no stake in the company but I have installed two timing kits from them in my 3.0 over the years. Good company. This is the same place SJorge3442 mentioned earlier.
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    Rock auto here as well, although I ordered parts from roughly 3 different sites, as there was always at least one part in a kit that cost double what it cost somewhere else. Between rockauto, fcp euro, and eurpoa parts, I was able to get everything plus some extra stuff for about 400 bucks. That included an eBay cam lock set too.
    Rolling through 185k, with 35k on the timing belt job.
    Sent from my LG-H830 using Tapatalk
    2011 TTS
    APR Stage 1|H&R Rear Sway|Bilstein B12 Pro-Kit|42DD Downpipe
    2002 A4 Quattro 3.0 6spd - sold
    ST Coils|RS4 Reps|Rebuilt 01E|Color DIS
    Sep 08 2016
    Grover Beach, CA
    So Fouad101, did you do the belt yet?
    Nov 25 2014
    2002 Audi A4 3.0
    Columbus, IN
    Sorry I havent posted here in a while. I got distracted with the new house. I just started doing the job. I borrowed a car from my friend so I'm taking my time with it. So far I got the the accessory belt off, and the valve covers. Not as much progress as i would have hoped, but its my first time doing a major service on a car. My problem now is even with the lock carrier in service position there still isnt much room there for me to get everything off. I found a walk through for the 1.8 where they were able to remove the lock carrier without unplugging the AC condenser lines. I am going to try that tomorrow to give me some room to work on this. I ended up picking up all the parts from a local parts store in town, got the belts, rollers, tentioners, cam and crank seals, Valve cover gaskets, water pump, thermostat, coolant overflow tank, snub mounts, and the coolant for 560. I will keep you guys updated as i go.
    Feb 10 2011
    MI
    I take the whole front end off, and the ac condensor slides under the engine and sits on a box. I sit in a chair and do the job. It's easier than service position.
    Apr 07 2011
    I agree. Especially for the first time, get the front clip out of the way.
    Aug 27 2013
    Philly
    For the 3.0 gettign the front clip moved out of the way is the ONLY WAY IMO. It takes an extra 25min, but that will save so much cussing and screaming, not to mentioned bloody hands or dropped tools.
    Nov 25 2014
    2002 Audi A4 3.0
    Columbus, IN
    Quick update on the job. I ran into a problem. One of the accessory belt tensioner bolts snapped when i was trying to remove it. Then when i was trying to extract the bolt, I broke the bolt boss on the front seal carrier thing. So now i have to replace that too.
    Nov 25 2014
    2002 Audi A4 3.0
    Columbus, IN
    One more thing. I cant seem to find the crank lock pin location. I need to lock the crank to take off the front seal and its housing. The other thing is that when i locked my cams, the mark on the crankshaft pulley did not line up with the mark on the timing cover perfectly. How close to aligned should those be?
    Nov 03 2011
    All Over!
    I just did mine.
    Bear in mind, the camlocks will only fit in one position, as the flats that accept the tools are tapered / wedge shaped. As for the crank lock, I've never used it. I simply make a mark on the sprocket, and use it as a reference. It won't move, as the camshaft sprockets are loosened, so they freewheel.
    1986 Type 85 Audi 90 quattro
    Nov 25 2014
    2002 Audi A4 3.0
    Columbus, IN
    My cam locks are fully seated. But the crank TDC mark wasnt matching the mark on the cover. I have to put in the crank lock since i need to replace the front seal and the seal carrier.
    Aug 27 2013
    Philly
    That pin location is behind the AUX water pump. Follow the lines from the oil cooler and you'll find it. Its a pain. Since your timing marks arent lining up, I bet your belt stretched causing your timing to be off. Don't worry about that now, just be sure to have everything lined up when you re-assemble
    Nov 25 2014
    2002 Audi A4 3.0
    Columbus, IN
    do i have to remove the AC compressor to get to it? I see the plug i just cant seem to be able to reach it
    Feb 03 2009
    Florida
    No. If you have the Aux cooling pump, remove the two mounting screws for that. Leave the hoses attached to the pump. Then push the pump up and towards the front of the engine. That will give better access to the plug for the crank lock pin.
    Edit: To fully seat the locking pin, use a breaker bar to rock the crank back and forth slightly while turning the locking pin by hand.
    Nov 25 2014
    2002 Audi A4 3.0
    Columbus, IN
    Quote Originally Posted by john_gonzo View Post
    I was able to get it by removing one of the AUX cooling pump screws and pushing the pump out of the way. Im going to need someone to rock the crank back and forth for me to seat the pin. There is no way for me to reach the locking pin and the breaker bar on the front on my own.
    Nov 25 2014
    2002 Audi A4 3.0
    Columbus, IN
    So i just ran into a huge problem. There doesnt seem to be a way to remove that front plate without pulling down the upper oil pan. This is such a bad design for a seal holder. Does anyone have any experience getting this plate out? or removing the upper oil pan?
    Aug 27 2013
    Philly
    Post some pictures of what you're dealing with. We need to make sure we're all on the same page.
    Nov 25 2014
    2002 Audi A4 3.0
    Columbus, IN
    Lets see if this picture works
    So this is the front of the engine. I know its filthy.
    https://goo.gl/photos/j5ssTazrMzHcmP1v9
    This is the bolt hole that i broke
    https://goo.gl/photos/XZLC8S7NFfYoAVzU9
    That is the plate in question (new one I just got)
    https://goo.gl/photos/wDKjVKgNkr9iJsMw9
    The problem is that the piece that sticks out from the bottom of that plate is preventing me from removing the current one. It catches on the upper oil pan.
    I hope this explains what is going on
    Jun 05 2013
    Lexington, KY
    I believe the upper oil pan has to be removed to get the flange out. Looks like you already got the crank seal out? You can install a new seal without removing the flange
    2011 TTS
    Aug 27 2013
    Philly
    Quote Originally Posted by cschuster View Post
    You are correct I believe. Are you replacing this front cover because you had an issue with the snapped bolt? Might be worth while to see if you can get someone with a welder to come by and try to remove that broke bolt for you. I found this list of steps on Audi World for whats needed to remove the upper oil pan, which sounds like a lot, but in reality, isn't.
    "the engine will need to be supported from up top , drain oil , remove lower pan , lock carrier in service position , unbolt a/c compressor , remove oil cooler housing , remove air pump , lower front of subframe , remove alternator , remove starter & after that it is a cake walk."
    May 02 2020
    Phoenix
    thanks has helped me a lot
