Results 1 to 4 of 4
Thread: Ticking at idle
    Senior Member Three Rings REVOofRustler's Avatar
    Jan 18 2014
    Redmond, WA
    Ticking at idle
    I'm back with another new noise my B6 is making! So on saturday I went to the auto parts store to dump out some old oil. When I got back in my car, I noticed a ticking sound I hadn't heard before. Drove it home, and it had gotten a bit louder. I went out the next morning and started it, and it was a lot quieter with the cold motor. I drove it to work today and it did the same thing; really quiet (but still noticeable from outside the car) when I first started it, and then just got louder til the motor was warm. I know timing chains are the "obvious" answer. I've been reading up on the procedure the last couple day in preparation for the job.
    The thing that's making me question if that's the problem, is that my startup rattle that I've had since I've had the car (1.5 years) is exactly the same as it's always been. I get a second or two of rattle on cold starts, and occasionally a very brief rattle after it's been sitting 30 minutes or so. If my guides were failing and causing a constant sound, shouldn't my startup rattle be noticeably worse? The noise I'm hearing is also different from the clatter I hear when I start the car in the morning. The chain rattle is more of a dull knocking, where this noise is more of a high pitched tapping. I've poked around a bit, but I cannot find a definite source of the sound. I scanned for faults but didn't come up with anything related. It still idles perfectly fine, and I have no check engine light or misfires. Any thoughts?
    The general source of the noise does seem like it's coming from towards the back of the motor. I got under the car and it sounded like it was coming from the direction of the power steering pump or ac compressor. I just replaced the ac compressor 4.5k miles ago, so I really don't think/hope it's that. Any thoughts?
    https://www.youtube.com/watch?v=mlHu7xF3yY8
    2004 S4 Avant 6MT Dolphin Grey
    | JHM Tune | JHM Short Throw Shifter Trio Package | Fast Intentions Dual 2.5 Resonated Catback | JHM 4:1 Center Diff | BC BR Type Coilovers | Hotchkiss Rear Sway Bar
    Instagram: tha_notorious_b | rotational.media
    Established Member Two Rings 1.8t's Avatar
    Jul 25 2008
    Failed lower guide. Had exact same issue. Just replaced all my guides, tensioners and both my mech cam adjusters. My lower guide was broken in 4 pieces. My start up rattle was also hit it more even after my ticking noise.
    Sprint Blue/Black B7 S4 Avant 6MT - KWV3, Catless Downpipes, Miltek Resonated Catback, Revo Tune, Hotchkis F & R Sway Bars, Flat Bottom Steering Wheel, RS4 Pedals, Ocarbon Trim, Ecs Snub mount, Michelin Ps2, OEM S5 Rotor Wheels, 6 Piston Brembo Calipers.
    Jan 18 2014
    Redmond, WA
    Now that I think about it, that would make sense. I wasn't considering that there's multiple chains possibly making multiple noises. Guess I'll start the tear down tomorrow!
    Jul 25 2008
    I actually didn't know what my issue was because no one had this issue I had, my engine light ended up coming on and thats when I had it all replaced. Now that I think back, I drove it for 4 months with the tick lol. I'm lucky engine didn't fail. No rattle while engine cold and then once it warmed up it was very noticeable
