Results 1 to 3 of 3
    Established Member Two Rings 1.8t's Avatar
    Jul 25 2008
    Dension Bluetooth coding with RNS-E - Help Please!
    Posted this in audio also*
    Hey Guys,
    I recently purchased a dension gateway pro unit and I'm having issues with the bluetooth working with my RNS-E. The RNS-E is showing me "telephone not available" even when bluetooth is coded in. I installed 2015 maps in the nav and updated the system as well. My RNS-E is retrofitted in and was not installed from the factory. VCDS doesnt allow me to communicate with telematics.
    I copied my brothers code from his b7 s4 and his coding is as follow; 0309677. He has OEM bluetooth, OEM nav, SAT radio all from factory. When I use the identical coding in my s4, the nav still displays no telephone available. If I do custom coding and add bluetooth coding in, still no bueno. I was told I need to code the dension in as a OEM bluetooth module. All other dension options work, ipod, usb, blutooth audi and my phone also detects the module. I just don't have the calling features working on the RNS-E.
    Im stumped. Any help is greatly appreciated.
    Thank you
    Sprint Blue/Black B7 S4 Avant 6MT - KWV3, Catless Downpipes, Miltek Resonated Catback, Revo Tune, Hotchkis F & R Sway Bars, Flat Bottom Steering Wheel, RS4 Pedals, Ocarbon Trim, Ecs Snub mount, Michelin Ps2, OEM S5 Rotor Wheels, 6 Piston Brembo Calipers.
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    Is this helpful?
    it's for a Fiscon unit, but the information may be helpful if the install is similar. it has VAS coding for the head unit and steering wheel controls.
    http://nickscarblog.com/wp-content/u..._Audi_1.23.pdf
    Jul 25 2008
    Thank you for the reply, already tried those codes and still same issue on rnse
