    Jun 22 2016
    northern Virginia
    Coilovers - Avant to Sedan
    I've found similar questions, but nothing directly addressing this question. Aftermarket ST Coilovers for an Avant, only difference is the spring rate in the rear? I've checked all the sites, spring rates are never published. Thanks in advance!
    Jun 22 2016
    northern Virginia
    Nada?
    I'm seeing the spring rate discussions everywhere but can't determine exactly what the difference in part numbers are between avant and sedan. I may swap rear springs anyway, so the spring rate isn't as much a factor, as I've read that using the avant kit may limit the ability to go as low.
    Thoughts? Thanks
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    The rear spring rates are progressive and the fronts are both 690lbs. Are you trying to put Avant ST coils on a sedan?
    Veteran Member Four Rings z_wrecker's Avatar
    Jun 15 2011
    02 Boxster
    Charlottesville,VA
    I ended up ordering some hyperco rears. I couldn't find the exact rates for the springs either. I know it is not much help
    2018 Alfa Romeo Giulia Quadrifoglio
    2014 Arctic White B.O. S5 Prestige manual w/ sports diff
    2002 Arctic Silver Metallic Boxster manual
    2018 Daytona Gray Q5
    2018 Daytona Gray B.O. S4 -Sold
    2009 Pearl White Ducati Monster 696 with Termi race kit, and a bunch of CF -Sold
    2008 Ibis White A4 s-line manual -Sold
    Jun 22 2016
    northern Virginia
    Quote Originally Posted by chris@fifteen52 View Post
    Hi Chris, yes, Avant ST coils on a Sedan (B7)
