Originally Posted by
EuroxS4
Those jacks are the bomb.As long as you know how to use them properly.On a flat surface/ground.Set parking brake.Then lift vehicle i have yet to see one fail.
I agree, the emergency jack is very useful when used as intended, according to instructions in the owners manual. I have never broken one either. The jack is specifically for changing a tire. When this is done properly it does the job required. Audi is not uninformed about emergency jacks. The same basic design has been used since the '70's or earlier.
I don't understand why so many guys are afraid of this jack. If placed in the specified locations, for each road wheel, lifting the car just enough to remove the road wheel is easy. IF the jack is unstable and is not lifting straight up, then that will be obvious before removing the wheel. If the car slips off the jack before removing the wheel, no harm can result. IF the lift is unstable, that will also be evident before the wheel is removed. If that is the case lower the car again and re-position the jack. Repeat until the lift is secure enough to remove and change the road wheel. Since there is no reason to ever be under the car supported by the emergency jack, there is really no justification for calling it the "Widow Maker", IMO. If the ground is to soft, or uneven, then move the car a short distance to a level area with firmer surface.
