Results 1 to 8 of 8
    Oct 12 2014
    j
    Map update Service not available issue
    Do you guys get this issue when you guys try to download the map from https://my.audi.com/?
    Apr 11 2012
    worked for me through www.myaudiconnect.com, but only for the "complete package".
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    Quote Originally Posted by will13k7 View Post
    Where is that? I can't find it under my account.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Apr 11 2012
    Quote Originally Posted by Baggio View Post
    my bad, cut-and-paste from the wrong tab:
    https://www.audiusa.com/myaudi
    Select Audi Connect Services:
    Register/Pick your car, then you should see this:
    Click on map update.
    Funny I just did it and saw the same "Service Not Available", but then clicked another Service, and then re-clicked Map Update, and it worked. I'm guessing when they get too much load it says "Service Not Available", so maybe just keep trying until you get it.
    Aug 28 2013
    It downloads an unrecognizable that's only 8kb in size. It's not working.
    Apr 11 2012
    It opened on my Mac by double-clicking it, it ran some Java program that does the actual downloading of the maps after you log-in yet again. Maybe you need to install Java?
    https://java.com/en/download/faq/java_webstart.xml
    Aug 28 2013
    That did it. java opened the download program. Thanks!
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    I tried to install new map update but once I put my sd card it needs erl highlighted.....also tried to connect via USB on my phone but same conclusion. Went to a Audi dealership and they told me be a useful I never initially had it done that it won't work for me....?!?!?!?!?!?! So he told me that it usually takes 3-4 hours for the whole process but will only charge 1 hour....I think know that's full of s@#$!!! So now my question is....
    how do I update the mmi navigation myself?
