Having slight OCD, it drives me crazy that my homelink will not work. I tried when I first purchased my pre loved 2014 S4 in February. I've been getting by with a visor clip on remote. So I brought her in for a 25K check up and had a list of little things for them to check out and one of them being that system. I can program it with my remote. Lights flash 3x indicating that a signal was received and a. Iron was programmed but it will never open my garage. So while she was getting fondled by an Audi tech they let me use a 2016 Q5. So to kind of rule out my garage door as the issue (being it's an old opener from about '95) I tried the same process and programmed the loaner. First try. Opened my garage. Fast forward a few hours...dealer calls and says they found my home link module was installed upside down and a wire was pinched in the process. First thing they blame was my install on my ecs intake. I call his bullshit. He says well either way someone did this and it's not covered under warranty but it's fixed. Only charge me $70. So wouldn't you know it... I get her home and still doesn't work. I cleared programming and did the same process as the loaner. Looked through MMI on the loaner and the homelink version, status and county code was the same as mine. Is anyone familiar enough with the system and the location of the module? I'd like to take a peek myself. Thanks for any help.
Sent from my iPhone using Craptalk
