Results 1 to 3 of 3
    Oct 31 2009
    California
    RNS-E repair/replacement/upgrade options
    I have one car right now - a B7 (2006 A4 Q SDN 2.0T Auto); in pretty good shape at 146k miles. I drive a fair bit, including on road trips and in cities, and while I've looked at other cars, I still like this car better, except for one thing -- the nav/audio/bluetooth. I'd appreciate some advice. I'll probably switch daily driver to a Tesla Model 3 and a truck in a couple years, but I'm willing to spend $1-2k to completely fix things, or less ideally.
    I have RNS-E, a dension with 30-pin spec dock and then a 30 pin to lightning adapter, factory bluetooth, bose, sirius.
    The main things I dislike are:
    1) My DVD seems to stop reading periodically and then lock up the machine. It was a dodgy update disc, so I'm going to re-burn from a stored copy. Otherwise, do I clean it? Or is it the drive dying? Would a non-DVD-R be better read?
    2) Bluetooth audio quality (the mic/speaker) kinda sucks; not sure if it's just my mic is bad or what. Is there an upgrade/fix?
    3) Audio (either direct 30 pin or via adapter) seems to have lots of ground loop noise or something. Whenever a phone is plugged into the cable, there's a high pitched whining noise, even if it's not the selected audio source. Also, I'd like to upgrade to direct lightning if possible with a new dock.
    4) Nav on RNS-E is obviously not as good as modern/live nav, especially live traffic. My phone with google maps is overall superior, but I really like the driver information display.
    I'm trying to figure out if it's worth replacing RNS-E entirely with something else (what?), or fixing components. Good installer in Seattle or SFBA would be good to know, too -- the place I used in Mountain View CA last time was not.
    Nov 10 2009
    Burlington, Ontario
    I think this thread will have everything you need if you decide to replace:http://www.audizine.com/forum/showth...t-Nav-installs
    If mine were to die I'd get the android one that's mentioned there. I just got my A4 on Saturday, but I had the same unit in my A3 many years ago and while its definitely dated it gets the job done for me. I haven't had any issues with the Bluetooth, so I'd bet your MIC is going if people can't hear you well. With that said, if it broke I don't think I'd bother to fix it and just get the one in that thread.
    Jun 27 2011
    Most feature packed solution would just be an aftermarket headunit.
    My bluetooth is fine so I'm not sure what the issue is there. Was the bluetooth a retrofit or installed at teh factory? The mic is in the headliner console where the sunroof and light controls are.
    I have yet to see any direct to lightning adapters hit the market. I have no idea why, but its been, what, 4 years of the lightning connector and not a bit of aftermarket support for it. Who knows...
    Ground loop noise is probably a bad or miswired adapter harness. I bought an adapter for my b6 and one of the pins was detached and grounding out on an adjacent pin causing tons of noise. I fixed that and the issue was solved. Could be something as simple as that.
    Nav disc sounds like a bad burn or scratched disc. For the discs I've burned, I only use Verbatim DVD+R-DL media and burn it really slow and verify the burn after. Never had an issue with seeking or anything.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
