Results 1 to 8 of 8
    Sep 06 2016
    England
    How to program an Audi A4 B8 8K advanced key fob
    One of my remotes lost it's prgramation suddenly
    The battery is OK (tested), but it will not lock / unlock the doors anymore (it does start the engine, it's just lost the "remote" key function)
    1- How can I re-program my remote FOB
    2- What could have been the reason for a sudden deprogramation ??
    Senior Member Three Rings Mina08's Avatar
    Apr 30 2014
    Classic Mini, and lots of bikes
    Sweden
    hmmmm just happened to me today...
    2011 2.0 TFSI S-Line Avant/S-Tronic/Quattro/Quartz Grey/19"OEM RS5 Rotors/
    CFBSWheel/VCDS+Mods/XCL+Mirracast/LED/R8Coils/3.0FMIC/K&NFilters
    Apr 30 2014
    Sweden
    going to try this when i get home
    http://www.audizine.com/forum/showth...?highlight=key
    Established Member Two Rings CaryS3's Avatar
    Dec 15 2013
    Mini Cooper Countryman
    San Francisco
    This worked for me:
    1. Replace battery on non-working fob.
    2. Verify battery is good when red light turns on on the fob after you slip new battery in
    3. Open door or trunk with working fob
    4. Hold down any "open" button (door or trunk) within range of car with non-working fob.
    5. All of a sudden the non-working fob started working again
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Funny you post this. I replaced my battery on Saturday and I lost all remote operations as well.
    Turns out I'm an idiot, and I installed the new battery upside down.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Apr 26 2014
    San Diego, CA
    I was going to try this procedure before I realized my battery was upside down. Not sure how much it may help your situation but it's worth a shot. You'll need a working backup key to perform this.
    https://www.audiworld.com/forums/tt-.../#post17382058
    1# you take one key put into ignition turn on.
    2# close door, lock it with the key hole on driver side,with the key you want to program.
    3#once it's lock take the key of the door out press the open button once or 2 or 3 or 4 times depending on which key is being reprogrammed(for the seats memory)you will see your side blink every time you press ,wait 6 secs press again once.take the other key in ignition out.
    close the door and try locking with the reprogrammed key.
    if you lost the program on other key it's just you didn't select the right memory,so set the right number for the right key
    Ex:my wife is 1# in memory seat,mine is 2#.
    so i had to press twice in 3# step.
    Veteran Member Three Rings VNA4's Avatar
    Jun 20 2015
    San Jose
    I couldn't figure out what was wrong with mine either...bought a new battery..tried everything..read bunch of threads...Still not working.
    THEN i read your post @adamazing LOL ! Mine was upside down as well...smh....Thanks Adam!
    Quote Originally Posted by adamazing View Post
    S4 B8.5 2014
    KW H.A.S. / EuroCode ÜSS Adjustable Sway Bar / AWE Touring Diamond Black / 034 Stage 2+ / DP 187mm / APR Stage II Carbon Back Pipe
    20 x 10 et35 StanceWheels SF01 [PowderCoated Diamond Black]
    SOLD
    AUDI A4 B8 Premium Plus Sport:
    CTS k04/ APR k04 File / AWE Quad exhaust / FMIC: TR8
    VIP VRC 13 : 19X9.5 / Tires: 255/35/19 / Solo werks Coilovers / OE S4 Front Brake Upgrade Kit
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Damn Californians!! ;)
    I'm as cool as a cucumber in a bowl of hot sauce.
