Car was running awesome until this. This morning got the code below, part throttle, just pulling into traffic. EPC light, sport diff fault, TPMS error, Brake Guard inactive, Air suspension fault, no throttle at all. Pulled over, everything okay on restart. I'm reading this could be software or could be vacuum loss. Any idea what it could be? I've reached out to EPL for their thoughts.
Address 01: Engine Labels: None
Control Module Part Number: 4G0 906 014 B HW: 4H0 906 014
Component and/or Version: 4.0l V8TFSI / H56 0008
Software Coding: 0A2500326546000E1000
Work Shop Code: WSC 00000 000 00000
ASAM Dataset: EV_ECM40TFS0114G0906014B 001008 (AU57)
ROD: EV_ECM40TFS0114G0906014B.rod
VCID: 2142105430EEC54A8F-8074
1 Fault Found:
4624 - Engine Torque Monitor 2
P1335 00 [036] - Control Limit Exceeded
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 98702 km
Date: 2016.09.06
Time: 08:14:10
Engine speed: 4042.00 /min
Normed load value: 53.3 %
Vehicle speed: 58 km/h
Coolant temperature: 33 °C
Intake air temperature: 30 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.546 V
Unlearning counter according OBD: 40
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
Readiness: 0000 0000
