Custom Fueling Setup (SRM/FUEL LAB) - 12AN Breather Catch Can setup - STK Expansion Tank
Upgraded some parts on one of the projects, BRAND NEW items for sale.
-Full Split Feed -8/-6 Return Fuel System
*$SOLD
-12AN Catch Can Breather setup
*Requires relocation of battery or a slim pc680 style battery. Mounts to existing stud behind factory firewall.
*Custom aluminum, baffled breather can w/ 3x -12AN ports & a single drain on the bottom. Wrinkle Black Powdercoat.
*-12AN Braided Nylon Hose & Nickel Plated Hose ends
*Oil Galley Breather modified w/ -12an Bung to connect
*Few Extra hose ends if you need to customize to your liking. This was fitted to a big single turbo build w/ -12AN bungs welded to covers.
$500 as depicted or add $250 for a pair of valvecovers w/ -12AN bungs fitted & powdercoated your choice of finish/color.
STK coolant expansion tank
-Mounts to ABS module for a tucked/cleaned up look with STK.
*Aluminum construction, sight glass for level indication, -6AN bleeder port, -10AN to hardpipe, Moroso cap. **No level sender neccessary
$150
PRICES INCLUDE 48/USA SHIPPING
EMAIL ME - [email protected] for fastest response
List Date: 9/6/2016
For more info, click here to view the original listing: Custom Fueling Setup (SRM/FUEL LAB) - 12AN Breather Catch Can setup - STK Expansion Tank
This item is no longer available.
