Results 1 to 4 of 4
    Veteran Member Three Rings scott99c2's Avatar
    Oct 11 2014
    Nashville, TN
    Downpipe install
    Anybody got a link or a pdf for install instructions for downpipes? I don't mind doing the work, I just want to see how involved it is ahead of time.
    Established Member Three Rings fatherdeath's Avatar
    Jul 20 2016
    2016 Honda CRV EXL, 2006 Dodge 2500 laramie mega cab, 1974 Buick apollo
    Tampa, FL
    watching this as well im going with down pipes and a xpipe on the factory sport exhaust once my car gets here in november
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    I never seen diy instructions (in for some) but what I can tell from poking around, you'll have to remove the heat shield from the firewall, not sure what's behind it but youll need to disconnect (or remove) whatever might be behind it to make space for the dp removal.
    Everything else should be straight forward when it comes to unbolting the DPs and bolting after markets back on
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Oct 11 2014
    Nashville, TN
    I'm curious if you have to lower the engine or do any crazy removal of items to get to them. I was surprised how big a b!tch it was to do on my AWD BMW.
