Results 1 to 24 of 24
    Nov 19 2013
    Suburban Washington DC
    How to tow with just the front wheels off the ground?
    If I tow with a wrecker instead of a rollback, how hard is it to disconnect the rear driveshaft? I could lift the back end to get access with the wheel lift.
    Jul 05 2015
    Lower Hudson Valley
    Quote Originally Posted by atikovi View Post
    Use dollies.
    Mar 25 2015
    Calgary
    A cheap tow could cost a ton of money in repairs. Flat bed only.
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    You don't
    Sent from my Nexus 6P using Google's ProjectFI
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    Quote Originally Posted by Geomatics_Tech View Post
    +1
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    I like how "disconnect the rear drive shaft" sounds like a viable option in your post. It's not. Get a flatbed.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Disconnecting the driveshaft is not worth the hassle. Not sure of your situation, but U Haul has auto transport trailers (flatbed) for $40 or $50 per day.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings MVR 155's Avatar
    Apr 04 2013
    2018 Audi S6, 2015 GMC Yukon Denali and 2002 Corvette Z06
    Bartlett, IL
    Quote Originally Posted by LINDW4LL View Post
    This^^^^^^^
    2018 S6 Prestige, Glacier White/Black, S-Sport, Driver Assistance, Black optic, Carbon inlays, Cold weather, Vorsteiner VFF 103's in carbon graphite.
    2002 Corvette Z06
    Nov 10 2014
    Apex, NC
    +1 on Uhaul
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Nov 19 2013
    Quote Originally Posted by evanb View Post
    Use dollies.
    Don't have dollies with wrecker.
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    A wrecker should have dollies that "wrap" around the rear wheels and jack them up off the ground.
    If you're ever calling for a tow, just make sure you let them know you have an AWD car. They'll send out a flatbed cause tow truck drivers typically don't enjoy rigging up those dollies.
    2013 S4 - 200mm crank pulley (3.162 ratio), 034 Stage 2+, USP intake, MercRacing HX, Sachs XTend clutch, SS clutch line, Borla exhaust, gutted cats
    Nov 19 2013
    Don't have a tow vehicle with a hitch. So disconnecting the driveshaft is more than removing a few bolts at the rear and sliding it off?
    Nov 19 2013
    Quote Originally Posted by Charles View Post
    I have my own wrecker, just doesn't have the dollies.
    Jun 06 2016
    Florida
    You have your own wrecker but don't know how to properly tow an AWD vehicle?
    2018 Daytona Gray S6 | S Sport | Black Optic | Carbon Atlas |
    2011 Phantom Black S4 | S-Tronic | P+ | Nav | Sports Differential | Titanium Package | Silk Nappa | SOLD
    Nov 19 2013
    I've never had the need to tow an AWD vehicle before.
    Nov 10 2014
    Apex, NC
    that's like a valet saying they never needed to park a stick shift car before
    Present:
    Jul 29 2016
    AB, Canada
    Quote Originally Posted by doug97gxe View Post
    lol, I work for a larger dealership group and always find it funny when a store employs a porter without stick shift skills
    2011 S4
    Oct 31 2013
    Morris County, NJ
    AAA it and have it done properly
    2011 S4 P+ 6mt | AWE Touring | Roc Euro | H&R OE/Bilstein/034 RSB | APR Stage 2 DP + CPS | TSW Bathurst 19X9.5 | Michelin PSS 255/35/19
    Mar 21 2015
    +1 on Uhaul
    That thing is not loaded correctly, weight should be centered over the axles. Those straps look small too.
    Nov 10 2014
    Apex, NC
    I rather have the tie downs firm in the front with minimal play.. But I towed that car over 10 times for over 150 miles each trip no problems
    Sent from my iPhone8s using Tapatalk
    Present:
    Mar 21 2015
    I would educate yourself some more on trailer towing. Heres a start,
    1. Use proper loading techniques.
    If you are loading a trailer with a vehicle or materials, proper balance is critical. You don’t want the heaviest items all the way at the front or all the way at the back of the trailer. Most trailers are designed to support the weight of the item(s) over the center of the trailer. Loading a trailer too heavy at the front results in too much tongue weight, unloading the front tires, making the tow vehicle hard to control. Overloading the rear of the trailer has the opposite effect, unloading the rear tires, which again makes the tow vehicle hard to control. When hauling vehicles, the front of the vehicle is usually the heaviest, so cars should be loaded front first on the trailer. Sometimes you simply can’t avoid loading a car backwards, if you do this, make sure that the rear of the car is as far forward as possible, putting the heavy load over the trailer tires.
    Nov 10 2014
    Apex, NC
    My towing days are over but thanks for the info
    Present:
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    Get a flatbed. Don't cheap out, because you'll end up paying for damages if you don't go the flatbed route.
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by StealthBlackA4 View Post
    He owns a tow truck he just needs to buy some dollies and write it off on his taxes
    Present:
