Results 1 to 40 of 56
    Nov 21 2014
    Montreal
    Cam Chain & Tensioner Replacement Question
    Hey guys,
    So I am in the middle of replacing my chain and the tensioner. Looks like the B version cam (pic below)?
    It's an 06 audi you think it's been already changed before?
    However just noticed the guide I was following said to replace the guide frame bolts as they are stretch bolts. Is this necessary? Because if you look at the cam chain service kit by ECS, it doesn't include any guide frame stretch bolts:
    https://www.ecstuning.com/Audi-B7_A4....0T/ES2718947/
    Veteran Member Four Rings Denio24's Avatar
    Jan 23 2013
    Chicago
    The hpfp cam lobe is the newer revision one. Looks like it was replaced. I'll edit my post in a few about the bolts, and yes if they are stretch bolts they should be replaced as it is an internal engine component.
    So i'm assuming you're removing the camshafts for the tensioner/chain install since you don't want to mess with the camshaft? The bolts that hold the guide frame which holds the camshafts down is done in three phases <---- These bolts must be replaced. (Tighten by hand - 8 Nm - and 90 degree stretch)
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Just undo the poly drive bolt on the exhaust cam. Dont start fucking wtih the girdle
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Oct 24 2015
    Perth, WA
    Yeah, no need for removing those.
    My respray thread
    Nov 21 2014
    Montreal
    I thought you have to remove the girdle in order to change the chain and tensioner while using the T10252 to hold the cam in place? I am not replacing the cam.
    Got all the timing tools for the job too...
    Oct 24 2015
    Perth, WA
    Nope, just remove the cam bolt and you can remove the gear and then the tensioner and then the chain.
    My respray thread
    Nov 21 2014
    Montreal
    Quote Originally Posted by Okedokey View Post
    No need to worry about messing the timing this way?
    Oct 24 2015
    Perth, WA
    You still need to lock down the cams.
    My respray thread
    Nov 21 2014
    Montreal
    How to lock cams without opening top? Maybe we are not talking about the same thing here, I may have caused the confusion not sure if the top part is called cam girdle.
    Do I have to lock cam with tool just like in the picture below?
    Nov 21 2014
    Montreal
    So sorry my fault, just checked it's called the valve cover, that's what I was referring to not cam girdle. So remove valve cover to lock down cams. No need to change the bolts on valve cover?
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    Quote Originally Posted by AudiKilla View Post
    No need to replace valve cover bolts. Make sure to not over torque them either when re-tightening them down. They require very low torque. It's around 10 Nm if I remember correctly.
    Senior Member Two Rings Danne_gg's Avatar
    Oct 17 2009
    Touareg TDI 2012, Lupo GTi track car,Audi A1 TDI, Arctic Panthera 550, Coronet 24 weekender(boat)
    Stockholm, Sweden
    I had to remove the girdle when I did this a few years ago.
    The bolt holding the exhaust cam wheel kind of exploded (I had the specific torxalike tool for the bolt), heard it's quite common.
    Removing the girdle was not that hard, and in the process I got a girdle not leaking oil (factory installment had started leaking)
    Oct 24 2015
    Perth, WA
    The VC bolts are stretch bolts and need to be replaced according to ElsaWin.
    My respray thread
    Nov 21 2014
    Montreal
    Is there anyway to check if the engine has ever been replaced? Just want to be sure there was no damage before.
    It's an 06 audi and seems like someone replaced the cam with the updated version. The fuel pump, cam and follower look pretty good, no damage on pump at all. I am the third owner and the guy before didn't have any maintenance receipts nor did he tell me if any work on cam was done. Just said he changed timing belt but all the hoses connected to the engine seem to have been opened up before by someone as the clamps are not original.
    The car is at 150 000KM now, was bought at around 120K.
    Feb 15 2016
    Cambridge,Ontario
    Follow this video. Although not perfect is a very good idea how to do it
    https://youtu.be/BuzsBQndgdQ
    Also seriously doubt VC bolts are stretch bolts. Had mine off a few times with zero leaks.
    Active Member Two Rings atvhead's Avatar
    Sep 06 2016
    A4
    NH
    TTY VC bolts? nope
    Nov 21 2014
    Montreal
    How do you turn the engine to align the cams so I can lock it with the tool?
    It can only be done from the Crankshaft bolt?
    Dec 04 2011
    Kansas City, KS
    No theyre not. Elsawin is a fucking liar
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    You have to turn it from below, 12 point 3/4 socket. You should be able to sneak from below without placing the front in service mode. Turn it clockwise until the timing marks line up and the rear lobes are just pointing slightly cross-eyed. This will mark cylinder 1 TDC and the cam position tool should drop right in.
    You can try to turn the motor using the front exhaust gear bolt but you may end up shearing it in the process. If you try this, take out your spark plugs to help engine turnover and avoid excess compression buildup making turning the engine much harder.
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Oct 24 2015
    Perth, WA
    Why do you have to turn it from below. Just use a breaker bar and appropriate socket and turn it from above?
    Regarding the VC bolts, they're $3 each approx, worth replacing as they have individual seals, whether you agree that they're TTY or not. Worth doing properly.
    My respray thread
    Nov 21 2014
    Montreal
    How exactly do you turn the engine from above?
    I can't do it from bottom cause I'm missing the 12 point socket! Need to find one, hard to find here in Canada.
    Feb 15 2016
    Cambridge,Ontario
    He meant do it on the same bolt but from the top. I find it a pain with stuff in the way. Doing it from the bottom is easy.
    Also they are cam aligning tools not cam locking tools. You still need to lock the exhaust cam or you are likely to destroy the tool.
    Just watch the video. Then come back with questions. It's all explained
    can you dig it ??
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by rongeur View Post
    I doubt it's speced at 3/4 as its an Audi. Anyone know the real size ? Is it 19mm based on the fact a 3/4 will fit ?
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    19mm and 3/4 interchange and yes 19mm is the correct size
    Sent from my SM-N900V using Tapatalk
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Jun 04 2011
    Clayton, CA
    can you dig it ??
    Hehe, that guy is aces
    See below
    Quote Originally Posted by audinutt View Post
    Good luck finding 19mm 12pt for reasonable price. German obscure tax or 5 dollars at Sears....
    As far as access from the top, probably possible but much more difficult than it needs to be. I have catch can hoses and rerouted valve cover hoses in the way as well. #bigturboproblems
    Build Thread
    Apr 24 2016
    California
    See below
    I have a 10 year old craftsman socket set that has one. I’ll rent it out for $25 haha
    2005.5 A4Q 2.0T 6MT JHM 2+, Autotech internals, CTS front mount, GFB DV+, 034 Street Density mounts + snub, H&R coilovers, B7 Recaros, Phil's V4's, maybe a k04 soon?
    Oct 24 2015
    Perth, WA
    Im confused. Before removing the timing bolt from the cam, turn it to rotate the engine and align with the locking tool. Then lock the cams and then remove the bolt. Really not that hard. The tool you need is http://www.ebay.com.au/itm/Volkswage...-/302011661133
    My respray thread
    Nov 21 2014
    Montreal
    Can you guys look at the picture attached below. Looks like 2 holes in the engine where I'm holding the screw driver.
    Does it seem normal?
    Jun 04 2011
    Clayton, CA
    From my memory, normal drainage to sump.
    Build Thread
    Nov 21 2014
    Montreal
    Where exactly does the "Camshaft Adjuster Valve O-Ring" have to be installed? I don't see it anywhere on the adjuster I took off.
    Oct 24 2015
    Perth, WA
    My respray thread
    Nov 21 2014
    Montreal
    Oh man thank you, does anyone know the torque on the tensioner bolt? Can't seem to find it in any guide, is it 14nm?
    Oct 24 2015
    Perth, WA
    Cam adjuster bolt is 15 lbs plus additional 1/8 turn
    Tensioner bolt is 7 lbs
    Valve cover bolts are 7 lbs.
    Cam chain case cover is 7 lbs
    hpfp bolts are 7lbs
    banjo bolt on fuel pump is 13 lbs
    union nut on hpfp is 18 lbs
    My respray thread
    Nov 21 2014
    Montreal
    hpfp bolts are 7lbs
    Thank you you are awesome!
    One last question, do I need to put sealant on the valve cover gasket?
    Oct 24 2015
    Perth, WA
    No, you shouldn't. You need to clean the mating surface and replace the gasket with a new one.
    My respray thread
    Nov 21 2014
    Montreal
    One of the cam adjust seals broke before I could put everything back seems to be pretty expensive for such a tiny thing.
    Oct 24 2015
    Perth, WA
    Yep, needs replacing too.
    My respray thread
    Nov 21 2014
    Montreal
    Would you change all 3 seals or just the one that broke?
    Oct 24 2015
    Perth, WA
    You can only probably buy them in 3's so if so replace all. When you do align each with their gap and compress all together as you insert.
    My respray thread
    Nov 21 2014
    Montreal
    So put everything back. Started engine, it was shaking every few seconds at first but after 10 mins no more shaking.
    Checked with my scanner, there was a pending code cylinder 3 misfire. Dunno why coils and plugs were pretty new replaced last year. Will pull them out again and check.
    Gonna drive for a few days see if anything is wrong then.
    I did notice a bit of oil if I use my flash from phone on the left side of the valve cover on the gasket. It's a bit shiny, will have to drive it more and see if it gets worse or not.
    But I did torque the valve cover to 10NM and in the right pattern as the guide showed.
    Oh and engine is definitely more quiet, no more tapping sound from the back of the engine. I used to hear the sound inside the car too now no more it's very quiet.
    I just hope timing is good, what you guys think.
