Results 1 to 14 of 14
Thread: Oil Level
    Established Member Two Rings armnloaded's Avatar
    Sep 06 2015
    Oil Level
    I just got an oil change and the same day its saying i need to add 1 L when i got like 4.6 Ish L. Should i add more oil or my MMI is not working properly? Thanks in advance.
    Sep 06 2015
    I just look on the receipt they used 5w30 i usually use 40s
    Mar 21 2015
    No dipstick? Get one
    Senior Member Two Rings MrTylerRaines's Avatar
    Feb 21 2015
    Ohio
    Yea definately get a dipstick, also depending how many miles you could just have a bad oil level sensor (another good reason to get a dipstick so u can diagnose)
    Tyler
    Sep 06 2015
    No dont have one. Yeah i should dealer sells them right?
    Sep 06 2015
    Damn the mmi was right bought a dipstick and low was oil so i filled it up.
    Sep 06 2015
    Got a dipstick and damn my cars eating way more oil than ever. I usually get atleast 1000k or so every month now its just eating oil if im not mistaken a quarter per 100 km
    Jan 13 2014
    nyc
    Armnloaded
    What year and how many miles on your od?
    Sep 06 2015
    2011 102k (km)
    Junior Member One Ring
    Jul 29 2016
    2015 Q5 3.0T
    Mid Atlantic
    I just checked my oil level. I have the 3G+ MMI interface (no dipstick). The level was below minimum but the warning light didn't come on! Usually the MMI interface says "Oil Level OK", it did not say that anymore. Why didn't it warn me it was low?!? Anyway I added oil and from what I can gather the difference between "min" and "max" is 1 quart. However I added the oil in small increments as to not over-fill it.
    Is there a recommended level? Any reason not to run it at near the max level?
    I bought the oil from the dealer, it was Castrol Professional OE 5w-40.
    Feb 21 2015
    Ohio
    Buy. A. Dipstick.
    Tyler
    Feb 21 2013
    Quote Originally Posted by armnloaded View Post
    2011 102k (km)
    Are you aware of the "Oil consumption lawsuit"? If not, type that into your browser's search bar and will find out a lot of details.
    Also check out this thread: http://www.audizine.com/forum/showth...1#post11902613
    Go to an Audi dealer and tell them you have the Oil consumption problem. This is a big job (upwards of $6k) and it is covered by Audi Canada. I just had a complete pistons job because of the same issue (i'm in Canada too).
    Good luck!
    Sep 06 2015
    Yes im well aware of that.
    Sep 06 2015
    Ill try to talk to that about it again thanks cos1!
    -Mac
