Results 1 to 35 of 35
    Senior Member Three Rings Low Flyer's Avatar
    Oct 25 2008
    MD
    MRC is putting a C7 4.0tt into a B8 RS4
    Hey guys, I just received my copy of Performance Audi and just read that MRC is putting a C7 4.0tt into a B8 RS4. Has anyone seen or heard any more about this? It sounds like an awesome conversion, I was wondering about engine fitment and gearbox.....makes one wonder....
    A fair amount of euros.....
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    I have wanted to do this for 1hr now.
    Just couldn't find a 4.0T for a decent price
    Sent from my SM-G900W8 using Tapatalk
    Senior Member Three Rings RyanJon's Avatar
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    I really do need to get my act together and get my car into MRC for their stage 2 treatment.
    Oct 25 2008
    MD
    Quote Originally Posted by s4matty View Post
    What gearbox would you use? Would you convert it into a 6sp using an O1E?
    Aug 15 2015
    2 feet
    Niagara canada
    I would use my dsg or the tranny from the 4.0T
    I ment to say wanted to do this swap for 1yr not 1hr
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    How much more does the 4.0t weigh?
    Oct 25 2008
    MD
    In the article, they have the motor test fitted, I am so curious about this. A 4.0tt with custom turbos like PTE 5858s would be insane in a B8 platform.
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    ^^Nose heavy too and altering vehicle handling dynamics but hella fun and burn outs for days
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    I wouldn't be surprised if this becomes a common swap some day. We've seen with a lot of the older Audi platforms that most/many of Audi's engines are basically interchangeable with little or no modification required as far as mounting and (manual) transmission compatibility is concerned.
    Quote Originally Posted by MrFunk View Post
    65lbs, according to Audi's self study guides for both engines. Not terrible by any means.
    4.0T - 483 lbs
    3.0T - 418 lbs
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    That is nothing, 65lbs.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Built bottom end, built Trans and a single precision 88mm turbo running 40psi would be fun...about 1500whp of fun lol
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Dec 29 2011
    The Bay
    Quote Originally Posted by LINDW4LL View Post
    4.0T - 483 lbs
    3.0T - 418 lbs
    Not bad on engine weight differential.
    Hardware is never an issue with many swaps but the software is the problem. These cars are no longer analog and simplex algorithms, they are way to integrated. Unless you can convince Syvecs ECU for plug & play... Not sure if S4 ECU can run a TT4.0 or S6 ECU compatible to run in S4 is the questions of the day?
    Oct 25 2008
    MD
    Hardware is never an issue with many swaps but the software is the problem. These cars are no longer analog and simplex algorithms, they are way to integrated. Unless you can convince Syvecs ECU for plug & play... Not sure if S4 ECU can run a TT4.0 or S6 ECU compatible to run in S4 is the questions of the day?[/QUOTE]
    What if you were to run a 4.0t engine, transmission, ecu and trans ecu? I believe Syvecs?? makes a standalone for the cl65 amg....using an auto. Isn't the transmission used in the 4.0t a standard auto transmission not dsg? Just thinking out of the box.
    Dec 29 2011
    The Bay
    Not sure if this is compatible with S4 but Syvecs is not cheap.
    http://www.syvecs.co.uk/products/eng...nge-vag-group/
    Veteran Member Four Rings 4RCFED's Avatar
    Aug 27 2014
    12' Audi S4 (sold), 18' Discovery HSE (V)
    Sandy Springs, GA
    Quote Originally Posted by Low Flyer View Post
    What if you were to run a 4.0t engine, transmission, ecu and trans ecu? I believe Syvecs?? makes a standalone for the cl65 amg....using an auto. Isn't the transmission used in the 4.0t a standard auto transmission not dsg? Just thinking out of the box.[/QUOTE]
    In the S6/7 it's a DSG, in the RS6/7 it's an 8 speed ZF
    2012 S4 (sold)
    Oct 25 2008
    MD
    I do wonder if the 8spd auto would drop in....would have to call the driveshaft shop to make a driveshaft.
    Oct 25 2008
    MD
    MRC posted first start up of the swap on Facebook, can anyone please link it to this topic for me?
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    Jun 21 2013
    DC
    Here's a nice link showing the intake/exhaust plumbing on the 4.0t
    http://redlinespeedworx.com/audi-s6-...turbo-upgrade/
    Apr 05 2012
    Earth
    4.0T - 483 lbs
    3.0T - 418 lbs
    It's actually less of a differential. Remember that they're putting the 4.0T into a RS4 which come with the 4.2 V8. The 4.2 V8 is 467 lbs in the RS4/5 so that's only a 16 lbs difference.
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    That sound!!!
    2016 S6
    Oct 25 2008
    MD
    It's officially in this month's Performance Audi, it is completed running a RS6 ecu.....
    Dec 29 2011
    The Bay
    S6/7 motor/tranny and wondering if ECU will work in S4? I wonder what's the cost of an S6/7 motor?
    Oct 25 2008
    MD
    They also performed some mods. Article states that it makes 750chp and 1150nm of torque and the B8 RS4 chassis is 400 lbs lighter than the RS6/RS7 platform.
    Oct 25 2008
    MD
    Sorry, misread the weight difference 300kg which equals 661lbs roughly.
    Veteran Member Three Rings jachien's Avatar
    Nov 12 2012
    Cerritos CA
    I'm curious if anything else in the car works. All the creature comforts and what not.
    2013 B8.5 S5 - Dual Pulley 189mm/57mm. EPL E85 Dual Pulley/DSG flash. Autotech HPFP. APR B8 Heat Exchanger. Injen Intake. Deleted Mufflers. 034 Street Motor Mounts. 034 Driveline Mount Inserts. KW HAS + H&R F:20mm/R:25mm wheel spacers. S6 Brake Conversion
    May 31 2014
    Alabama
    I, too, contemplated doing this. But, for 30 mins!
    *SOLD* 2014 S4 | Glacier White | Premium + | DSG | 034 Drivetrain Mounts | ECS Slotted Rotors/StopTech Pads | IE Intake |
    Jan 19 2016
    Harrisburg, Pa
    Drool
    Sent from my SM-G900V using Audizine mobile app
    Jun 05 2015
    Manchester
    I was recently at my local Audi specialist - he has been looking after my car for over a year now. He is the garage my local AD recommended to me when I had a DSG issue.
    What he had there has put me off MRC - an RS3 which he was having to do a total rebuild on after the owner took it to MRC for a tune.
    He said the tune was way off and detonated the engine. Not only that but they messed up the ECU so bad that he could not flash it back - he had to order a new ECU and recode the whole car.
    Not sure I would take a car to MRC now.
    Senior Member Three Rings xpoweruk's Avatar
    Feb 05 2016
    UK
    & the garage is ???
    Custom stacked chargecooler
    revo Stage dual pulley with revo intake
    Milltek ValveSonic Exhaust Q5 Brembo 4 Pots
    18x9 Wolfrace ProLite alloys
    Eibach rear ARB & Eibach springs
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    That's the first negative comment I've ever read on any forum about MRC.
    Surely if they were thst clueless and with the amount of cars they tune there would be threads all over the place ripping them to bits?
    Maybe there was underlying problems with his engine and the tune tipped it over the edge
    Jun 05 2015
    Manchester
    Quote Originally Posted by RyanJon View Post
    Not sure. From speaking with the person now tasked with rebuilding the car it appears MRC don't want to help the owner out. The person also says this is not the first MRC car that he has had to "fix" due to tuning issues.
    Feb 05 2016
    UK
    So what garage is regularly fixing MRC cars then ?
    Jun 05 2015
    Manchester
    Quote Originally Posted by xpoweruk View Post
    I'm not at liberty to say, however I will be there in the new year and provide photos if car is still there.
    Oh and I didn't say it was regular, just that it was not the first time. Could be second car? Could be 50th. They didn't specify.
    Feb 05 2016
    UK
    Quote Originally Posted by sebgreen View Post
    I know they had issues with an EA888 S3 with cracked pistons iirc
