Results 1 to 7 of 7
    Oct 20 2012
    Danbury
    PRNDS interior lights not working
    For the past two months i noticed that on my 2009 Audi A4 that the interior lights near the gearshift (PRNDS) have not been working. Everything else on the dashboard lights up except for the (PRNDS). I looked in the car manual to see if it might be a fuse, but i didn't really find anything useful and a google search showed up nothing useful as well.
    Has anyone ever had this small issue?
    I also have another issue in which a couple people i meet from audizine tried to help me with but no luck in fixing it. I have ecodes installed on my Audi and they simply don't work. The only thing that works is the left headlight bulb. The DRL's on both sides don't work and the bulb on the right headlight doesn't turn on. Also the right side fog light doesn't turn on but the left fog light does. With the help of fellow Audizine members, they were able to use vagcom to input the coding again this all happened after i took my A4 in for a 75k mile service in which the dealer put the coding back to stock.
    Does anyone have a ideas on what is causing my headlights to not work? The headlights are functioning as they are brand new and the wires are in good shape. Maybe there is a blown fuse?
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    You can pull up the prnds near the gearshift super easy. Just yank up. It might be disconnected or broken. Easy to replace.
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Still no luck with the headlights bro? Damn.
    Sent from the Pedal Responce boardroom
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Jun 06 2017
    Connellsville PA
    Bumping this after searching for an hour. This is the only situation I can find matching my own.
    OEM xenons and only the driver's side works. Only driver's side fog light as well. The interior PRNDS lights are off, as well as the push button start and the red convenience lights that illuminate the console at night. All fuses are good. This all started after I disconnected the battery for a short amount of time to install air ride power and ground wires and messed with a few of the fuses. Blew one in the rear set for the cigarette lighter, 15a, swapped it out and still nothing.
    This issue is exactly what is going on with my car and I'm afraid it has to do with the computer being reset but I'm not sure what would even need changed in vagcom at this point if that were the case.
    Any help at all would be greatly appreciated.
    Sorry for reviving this old post.
    Aug 23 2018
    Panzer I have the same issue did you ever figure out what the problem was?
    Feb 21 2022
    mississauga
    was anyone ever able to get this resolved. I am having the exact same issue with by 2012 a4 and cant find a blown fuse,
    Jun 06 2017
    Connellsville PA
    I had resolved my issue, but mine was because my car was bagged and I had a fuse tap in the driver's side dash fuse box. It had spread the one side of the fuse holders metal legs too much and was causing the fuse to not touch anymore. Take a pair of needle nose pliers or hemostats and squeeze them back shut inside the fuse panel. I forget which fuse it was though because it was almost 3 years ago now.
