Results 1 to 16 of 16
    Established Member Two Rings pcardenas's Avatar
    Sep 04 2014
    S4 B8, Audi Q7
    México
    Cool Just clean my headlights (inside) yesterday
    Based on the info in this excellent forum (search in diferents post) I was able to clean my headlights inside because has like fog but inside the lights.
    First, take off the headlight , 4 bolts , easy , no more than 5 minutes.
    then take a look at the "damage" or dirt inside the headlight
    the "tricky" part was separate the cover from the headlight, that was using a HEAT GUN carefully heat all the seal material around the head light, I bought the heat gun specially for this.
    Once Warm just pull apart the cover from headlight
    then clean the cover Inside
    The Final RESULT:
    Thanks to all people who make this forum and excellent tool for improve our cars!!
    _________
    Paulo
    S4 B8 2011 , Dual pulley , Revo 1+ , custom Brakes , bilstein b8 , H&R Rear Sway Bar, CR15 mod, Pipercross Air Filter , Magnaflow xPipe 11386
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Nice wright up, thanks for posting it. Your lenses were a mess! Mine have dust on them, but nothing like that!
    Great job, I am sure it made your headlights brighter and improved the looks of the car based on what you showed in that one pic.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    I need to do this. Mine are looking shitty. How is the lens bonded onto the housing? Glue or clips??
    Established Member Two Rings Silverrotor's Avatar
    Jan 06 2015
    Badass 87 Mazda RX-7 Turbo
    Vaughan Ontario Canada
    Are replacement lenses available for the b8?
    It would be nice to replace both lens at the same time awhile wrapping the awful orange corner.
    Established Member Two Rings <3S4PLAY's Avatar
    Mar 25 2015
    Bay Area
    Quote Originally Posted by derek.kritz View Post
    It's bonded with both glue and clips
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Quote Originally Posted by Silverrotor View Post
    https://www.theretrofitsource.com/co...1#.V83V6En6uUn
    http://www.audizine.com/forum/showth...eplacement-DIY
    2016 S6
    Sep 11 2015
    2003%20VW%20Jetta%201.8T
    Western Mass
    What did you use for a cleaner?
    2015 Mythos Black Pearl BO 6MT S4 P+ | 19" peelers | Nav | Carbon inlays | B&O | Sport Diff | Nappa
    Mods: 20% tint | EPL | OEM Audi Sport plate frame | HOEN fogs |ECS 10/12.5mm Spacers | Hardwired radar | ECS Trans insert | CTS intake | AWE Touring Exhaust - stock DPs | H&R OE Sports + Koni Shocks | Eurocode F&R Sway
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    Plexus is a great cleaner for plastic
    May 17 2012
    Houston, TX
    What did you use to seal the lens back on? Or did you just re-heat it and reassemble?
    Sep 04 2014
    S4 B8, Audi Q7
    México
    Quote Originally Posted by AKPS4 View Post
    re-heat it and reassemble.
    _________
    Paulo
    Jan 06 2015
    I meant a replacement lens for the entire headlight housing. :)
    Veteran Member Three Rings EHesh14's Avatar
    Jul 16 2010
    Colorado
    https://m.aliexpress.com/item/323952...08.4.22.MaAOVh
    I replaced the lenses with these and they are perfect fit
    Feb 08 2016
    Mexico City, Mexico
    I need to do this to my lights . They look very similar. I just need to get the courage to heat them to put them apart. I bought this form amazon to seal them back together (someone on the forum recommended this so I take no credit). https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by ebarberena View Post
    I need to do this to my lights . They look very similar. I just need to get to courage to heat them to put them apart. I bought this form amazon to seal them back together (someone on the forum recommended this so I take no credit). https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    You should have plenty of sealant left over from pulling them apart to re-seal them.
    I am pulling mine apart in a few weeks to black them out. I was planning on reusing the factory sealant.
    Geoff
    Jul 16 2010
    Colorado
    It's not bad at all to take them apart. Just un clip the clips that hold the cover and housing together and take about 5-10 minutes going around the headlight with a heat gun. It will take some force to pry them open,
    But they will come apart.
    I bought some butyl sealant from lightwerks thinking I was gonna need to re seal the new covers completely, but you'll still have enough to just stick them both on. I just added some new sealant to some corners for good measure. Haven't had any condensation build up inside the lense since I did this 3 months ago and Colorado has had a good amount of rain.
    Active Member One Ring Fitztacular's Avatar
    Apr 20 2010
    Fort Lauderdale, FL
    I’m very late to this party, but if anybody has any before/during/afters of later models, please do share! Considering this on the tri-projector (probably not what it’s called) headlights.
