Results 1 to 14 of 14
    Senior Member Three Rings Badger Audi's Avatar
    Feb 05 2014
    B8.5 S4
    San Diego, CA
    Help! Manifold Question
    On the cusp of buying a B6 S4. When I looked at the engine yesterday, I noticed the manifold seems to be melted(ing?). I have a few questions: Is this common? How problematic is this? Is it an easy fix? How much? Is this a deal breaker? Pic below. Thanks for your help!!
    [IMG]IMG_2996 by M S, on Flickr[/IMG]
    Current:
    2013 Audi S4
    Previous:
    2005 Audi S4 - sold
    2012 Audi Q5 Premium Plus - sold
    2004 Audi A4 Quattro 6MT - sold
    1997 Audi A4 Quattro 12v - sold
    Apr 26 2016
    Kia Sportage V6 - Wifes car
    Metuchen New Jersey
    wow.. I've never seen that before... but considering that the manifold is made from plastic/composit material... I would venture a guess that , that bank may have overheated at one time, have you done a compression/ leak down test, and have you borescoped the cylinders?.. that would be the first things I would do before buying...
    I could be wrong, but that's my guess... I'm sure someone who knows more will chime in...
    Sent from the S4 with a Tap!!!
    My S used to have a tap, a valve slap... now it makes no noise at all! RIP
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by chain_slappins4 View Post
    are you sure about that ? from what I've heard/read , the manifold is made of a certain aluminium-magnesium alloy.
    my manifold looks a bit like this around the injector holes, seems like the paint/coating is becoming detached from the surface( I'll have to powdercoat it soon)
    Apr 26 2016
    Metuchen New Jersey
    Quote Originally Posted by jakeoboy67 View Post
    it seems way to light to be made of a metal alloy, I could be totally wrong, but I've machined magnesium and it's a bit heavier.... I hope I am wrong for the sake of the OP...
    also, if you look at the bottom of the manifold, it almost looks like it's been wrapped..... but again, like I said, i hope I'm wrong
    Jan 29 2010
    north ga
    most B6's came with a magnesium alloy intake. B7's came with plastic
    Apr 26 2016
    Metuchen New Jersey
    ahhhh maybe that's why.. I've never pulled the IM on my B6, only the B7 that's being parted out.... well I did say that i.hoped I was wrong..
    Feb 05 2014
    B8.5 S4
    San Diego, CA
    I haven't ran a compression test on the car yet - will have it done this week.. Car runs fine and doesn't overheat on temp gauges, has reg oil changes and isn't burning oil.. I know the owner re-powder coated the top of the manifold when he did the valve covers.
    Is this a red flag? I could always get a new manifold to throw on the top, if it is that problematic.
    Current:
    2013 Audi S4
    Previous:
    2005 Audi S4 - sold
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    I have 2 tops. Couple scratches on the paint. Can sand blast one if you want to get it powder coated. Pm of you want to talk more on it.
    Senior Member Three Rings AllroadMass's Avatar
    Oct 30 2015
    Massachusetts
    My wife's 4.2 allroad manifold is doing something similar. I think the paint is just flaking off. Hope you snag it soon.
    Feb 05 2014
    B8.5 S4
    San Diego, CA
    I might upgrade the manifold anyways, which hopefully would happen within the first few months of owning the car. I made an offer on this thing yesterday and am hoping to be an S4 owner by the end of this week :)
    Current:
    2013 Audi S4
    Previous:
    2005 Audi S4 - sold
    Oct 30 2015
    Massachusetts
    Sweet! Good luck. I've only put a little over 2k miles on it but I love it so far.
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    Quote Originally Posted by BCsniper View Post
    B7 is same as B6 composite... its just coated with a plastic substance on the outside...
    PAST
    2004 Audi (B6) S4 4.2L
    2006 Audi (B7) S4 4.2L 25th Anniversary Special Edition #167
    Current
    2015 Audi (B8.5) A4 2.0T P+ Sline ECS-Luft-Technik Intake System/Air Scoop v2/Silicone Intake Tract Set with turbo muffler delete, GFB DV+ VTA Performance Blow-Off Valve, JHM FMIC/ECU and TCU (Automatic 8 Tip Quattro) Stage 2 tunes. Cosmetic RS4 Honeycomb Mesh Front Grille and Fog Light Vent Grilles
    Nov 30 2014
    Dallas, TX
    My intake manifold cover's paint chipped pretty badly, had to powder coat it. My valve covers are doing a similar thing so they'll be done soon. It also looks like you have a broken "V8 - 4.2" vanity piece.
    Oct 29 2015
    Richmond VA
    Maybe he sprayed it with brake clean or some other harsh substance to clean it up a bit. Ate the paint away
    2013 TT RS (Sold)
    2013 Allroad (Sold)
    2017 S3 (sold)
    2006 25 Quattro S4 #50 (dead)
