Results 1 to 13 of 13
    Junior Member One Ring
    Jul 20 2014
    Fairfax Station, VA
    D2 suspension replacement suggestions?
    I have a 2001 D2 A8L with 125K miles, and sketchy maintenance before I got it. I'm between jobs, so sourcing best of class (i.e. really expensive) parts isn't my first choice...but I'm open to considering them.
    Anyone have recommendations of high-quality, reasonably priced aftermarket parts for front and back suspension parts and/or suspension kits? If I can save money by getting a complete kit with all the control arms and struts, I'd lean that way.
    Thanks for any helpful feedback and you all have an enjoyable Labor Day Weekend! John
    Senior Member Two Rings Jeremyboukaia's Avatar
    Aug 20 2016
    Elpaso
    I plan on doing these
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    Quote Originally Posted by Jeremyboukaia View Post
    Is it true that with the coil overs, the rears are not adjustable? Kind of looks that way from the photo as well.
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Veteran Member Three Rings AndreNY's Avatar
    Apr 06 2005
    Boston MA
    with any coilovers for a D2 you cannot adjust the rear, so they are basically Front Coilovers only and rear is just a spring. I had 2 sets of Coilovers (H&R) on my A8 and (KW) on my S8 and they were both the same, so I had to "modify" the rear to get it lower :)
    Aug 20 2016
    Elpaso
    The rear spring pirtch is adjustable. The range is dropped 1.2 -1.8 the front is adjustable from 1.2 - 2.4 inches
    Aug 20 2016
    Elpaso
    They look like this
    Apr 06 2005
    Boston MA
    that perch is Junk you cant even get half inch out of it
    Aug 20 2016
    Elpaso
    But it is adjustable lol well if you want to go low then take the screw off that should give you skittle more adjustment
    Jun 05 2013
    Ottawa
    Thanks for clarifying.
    By "modifying the rear" do you mean just leaving the threaded perch in without the adjustment collar?
    2007 RS4 Avant
    Aug 20 2016
    Elpaso
    Yes that's what I mean. But you won't have to it will give you the right look. And if this car is a street car like mine then this is all you need
    Jun 05 2013
    Ottawa
    Just finished looking at it and 1.2" would be plenty for the rear. The fronts on these PFLs are brutal! So much gap compared to the FLs.
    2007 RS4 Avant
    Aug 20 2016
    Elpaso
    Ya I did a solowerks cool suspension on my wife's b7 avant and yes I won't track the car and the kit was cheap but for the street the ride is amazing the car at its highest height is so low we can't use car washes anymore we hit the track that gides you lol
    Aug 20 2016
    Elpaso
