Recently noticed at idle my rpm's jump up from about 900 to 1200 and back down - repeating (almost like my old e46 M3 did on cold starts). When I take off the oil cap their is a bit of vacuum and the car dies. If I take out the dip stick, the bouncing idle smooths out to almost a normal idle.
I vag checked the MAF on a 1st gear pull and seems in working order. I also unplugged the MAF and the idle still bounced.
I vag checked adaptive values while then bad idle was present and got:
Bank 2
Idle -1.5%
Partial -4.7%
Bank 1
Idle -2.3%
Partial 0.0%
I did see some misfires on initial cold start spread out to almost every cylinder. As soon as he idle came down to normal the misfires disappear.
I also noticed the other cold morning start the initial start up rpm was much higher than usual and then as it comes down it is a little rough.
Once I unplugged the dip stick and got the idle to smooth out, checked the trims and everything was smooth. Car ran much better, more power for last couple of days. Last night I noticed the bouncy idle was back.
Gut is telling me the oil separator, however wants some I out before I start trying to throw parts at her!
Also, do the intake runner flaps have anything to do with this phenomenon? I vag checked the runner plates and it showed position anywhere around 60 - 70% while spec calling for 0 or close, I assume? I have JHM tune with the flap error code eliminator so not sure if the flaps are a problem.
