Results 1 to 11 of 11
    Established Member Two Rings deedle1.8t's Avatar
    Nov 30 2006
    2016 A3 SLine, 2013 GMC Acadia
    Huntsville, AL
    Sport suspension and springs
    I'm sure this has been covered here a number of times but can't find anything for the MQB platform. I'm in a lease of a 2016 Sline (summer of Audi package). Wanting to put a slight drop with HR sport springs. How do the stock dampers hold up? I've read and heard of premature failure to the latest dampers are far better than they used to be. Is anyone running this setup and if so how's the ride (bouncy) anything negative about it? Pics would be great.
    THanks in advance!
    Veteran Member Three Rings INYAUDI's Avatar
    Feb 21 2016
    Southern New Hampshire
    You have to take it all apart no matter what. Might as well buy the supporting mods. Then at that point you'll be kicking yourself because you're $200 away from having height adjustable coilovers.
    Instagram: TonyConQuattro
    Established Member Two Rings photocycler's Avatar
    Jun 07 2015
    United States
    A lot of people prefer the Emmanuelle design ones for comfort
    Nov 30 2006
    Huntsville, AL
    I was actually just reading up on those and seem to be a perfect give/take if they are designed to use with the stock dampers. I would probably assume they do not perform quite like H&Rs would though.?
    Quote Originally Posted by photocycler View Post
    Veteran Member Three Rings TheDarkness's Avatar
    Jul 13 2008
    15' A3 2.0T , b5 S4 Stage III
    Do Coilovers . End Thread.
    2001 Stage III Pearl White B5 S4: Frankenturbo F21s | Iforged Flux | Solo Motorsports Dyno Tune | Bosch EV14 52#
    2015 A3 2.0T 8V Mythos Black: KW V3s
    Jun 07 2015
    United States
    Quote Originally Posted by deedle1.8t View Post
    They won't handle as aggressive as H&R springs. You can put a stiffer sway and end links to get back some performance but at that point prolly better to go H&R if you are looking for more performance and don't mind sacrificing ride quality
    Feb 21 2016
    Just updated minutes ago, @emmanuelledesign springs are $229
    Nov 30 2006
    Huntsville, AL
    May have just sold me!! I'm all about ride quality as I have a commute for work, but on the fence about the performance side of things. I would think they would still perform better than stock correct?
    Quote Originally Posted by INYAUDI View Post
    Feb 21 2016
    Cant say from first hand experience but I'd say it does improve performance. I personally have Bilstein B14 coilovers and there are many people who feel it's right in the middle of comfort and performance. With the edge towards performance, after all it is a coilover. The cost of parts in this topic isn't where the money will go. If you do it yourself; for the price of a spring + install at a shop, you can afford a very reputable coilover.
    Follow my build on Instagram: @towknee603
    Veteran Member Three Rings 1S32K16's Avatar
    Jul 07 2016
    I have the ED springs. First off ride wise much better than stock. Not as bouncy and more comfortable on the freeway and roads. For performance they are also better than stock. For the price they are the way to go. If you want serious performance and adjust-ability the Coils are the way to go. But I love getting in my car even more now and ripping corners plus the height is perfect with the springs.
    2019 Quantum Gray SQ5 with black optic package, 20% Rayno Ceramic tint, TAG Motorsports Painted Front Reflectors, BMC Air Filter, JB4, 034 Trans Mount, OEM Black Badges, 21’ BC Forged RZ39, Redstar 200cel DP, ODIS factory lowering
    2016 Monsoon Gray S3 with black optic package, Emmanuele design springs, rear sway bar and endlinks, 19' Forgestar CF5's
    Junior Member Two Rings docss26's Avatar
    Aug 18 2016
    Chicago/Illinois
    Anyone have experience with s3 springs and s3 front and rear sway bars? Got a good deal from a forum member.
