Results 1 to 13 of 13
    Junior Member Two Rings DecadenceFTW's Avatar
    Jun 08 2014
    The Land Before Time
    C7 A6 1/4 Mile Fast List / Stock vs Tune Stats
    I see a lot of stuff about S6/7's and how fast they are stock and tuned, but not much about the A6. Why is that? The A6 is a great platform to start with, and an excellent one to tune. So why is there not a list for people with the A vs S who might have a Stage I or Stage II tune? No interest? If I do end up getting the A6, I am making it my personal responsibility to provide stock/Stage I/Stage II numbers for forum members. That's 0-60 times, AWHP dyno numbers, etc. I have an HD cam, GoPro, and other tools that I plan on doing comparison videos with. Sooo...assuming I get home in one piece...and assuming I do pick the A6 and not the B9 S4 or C7 S6...then you will see these things. :)
    "In the real world, some are destined to rehabilitate, what others strive only to destroy." - CD '08
    2012 Corvette Grand Sport - Cyber Grey Metallic (CGM) - Stock
    Mar 02 2009
    State of Confusion
    There is a lot of info on tuned 3.0 motors in the B8 and B8.5 S4 section. Just more interest there. I would bet that most with S6, S7, A6 and A7 owners don't flash tune their ECU just because of the buyer demographics. Look up bhvrdr and he has lots of info on chipwerke piggybacks and Unitronic ecu flashes. That search will lead you to lots of other info including stage 2 flashes with a smaller supercharger pulley and an oversized crank pulley. EPL had a deal including an oversized crank pulley and a flash for it.
    I would also check around because the last time that I checked, the newer C7.5 3.0 TFSI motors have a new ECU that hadn't been cracked by any of the tuners. It could have changed since I last checked though.
    Jun 08 2014
    Quote Originally Posted by mjfloyd1 View Post
    Yea, I frequent the B8 and 8.5 S4 sub-forum, I guess I was hoping to see something specifically for the A6. It's heavier, different breed of car...would love to see its own brand of attention, not something regurgitated from a different car. But maybe I'm asking too much haha.
    I guess I thought that guys get an A6 because it has the same engine as the S4...but with more luxury. So since it's a bit detuned or has to carry more weight, or whatever...I figured throwing an APR Stage I or equiv on the A6's would be pretty standard. Guess I was wrong. I would be getting a C7, not 7.5, although I have been reading up on and subbing to the threads about problems people are having with tuning them.
    Veteran Member Four Rings ntsantos's Avatar
    Dec 06 2015
    San Ramon, CA
    I'll eventually post the results of the different stages my A7 has been through as soon as I get time to hit the track. I unfortunately don't have any stock results, dyno, track times etc.
    I agree on more A6/A7 info since the only cars to compare to are the B8S4. The 2 biggest differences that make for an apples to oranges comparison is the weight difference and ZF tranny.
    Established Member Two Rings AY6NYC's Avatar
    May 22 2016
    Queens NYC
    when I got this car i too wondered why there wasn't a dedicated thread for performance on the non-s. I have read that the 2012/2014/2016 all have different performance times.
    Sent from my SM-N920V using Tapatalk
    Senior Member Three Rings luv2sleep's Avatar
    Jun 12 2012
    Quote Originally Posted by DecadenceFTW View Post
    Between here and Audiworld, there's some good info on tuning the A6 & S4 (more specifically, the 3.0T). I loved that supercharged engine and it has a lot of potential. I used own a C7 A6.
    Since you are considering a C7 S6, I'd test drive them both extensively before making the purchase. I'll just it at that.
    Jun 08 2014
    Quote Originally Posted by luv2sleep View Post
    Sounds good, I don't frequent AudiWorld as much. I'll swing in over there and see what I can find. :)
    Veteran Member Four Rings PKmode's Avatar
    Sep 19 2005
    Milwaukee, WI USA
    I'm stg2 APR and will take my C7A6 to the track at some point for just for fun. I expect a mid to low 12 at ~112-115mph. The biggest factors are RPM range due to the ZF and the actual gear ratios of the 8spd ZF. The low RPMs make a significant difference compared tot he S4s as these motor make their highest HP in the later RPMs. I'd driven several modded B8(.5) S4 as a point of reference. My car also easily walks stock B8(.5) S4s.
    I thought of doing stock through stage changes on the dyno as we have a local AWD dyno that I'm able to get on easily. The tuner didn't make himself available to meet at the dyno and go through each thing (understandable as it's time consuming). I'm curious to see what APR is getting ready to launch (dual pulley, E85?). I think this is a great platformbut for those after the big performance,they're likey to go straight to the S/RS.
    Do it right, or don't bother.
    Senior Member Three Rings Carl Weathers's Avatar
    Dec 20 2014
    Chicago
    Love my Stage II C7 A6. Unfortunately, I maxed out on my performance mods a year after owning it. Now I want an S6 but would be throwing away all the money I put into the damn thing already. Such is the life of the automobile enthusiast, I guess.
    2012 Audi A6 3.0T Fully loaded sans B&O/Nightvision, 20" Rohana RF2 wrapped in Ventus V12, APR Stage 2, AWE exhaust
    2005 Pontiac GTO, Procharged with D1SC 553/550 at rear wheels on 7lbs of boost
    Established Member Two Rings Cruxin's Avatar
    Dec 22 2014
    Milwaukee, WI
    Quote Originally Posted by Carl Weathers View Post
    I feel it is time to get this thread going again. I recently put on the APR dual pulleys, and am running the APR stage 2 tune. Hoping the rain takes a break so I can head to the Grove and put down a few passes. Then I will continue waiting for the release of the C7 A6 dual pulley tune that should be available in 2-3 weeks lol.
    What times are you guys putting down for stage 2?
    2012 A6 3.0T Prestige - Midnight Blue Metallic, Nougat Brown Interior, LED Headlights, Sport Package, B&O Stereo
    Veteran Member Three Rings 3rdBNCC's Avatar
    Jul 18 2014
    2014 Audi RS7
    Vero Beach FL
    We have the 3.0t database waiting for you guys to hit the track!
    2014 RS7 Daytona Gray Pearl APR Stage 2
    10.319 @ 131.82 on GT260+
    Video:https://youtu.be/qnqCdZK3KnE
    IG: @Spikes_RS7
    2018 RS3 Mexico Blue Stage 2 (For Sale)
    2017 RS7 Performance Glacier White (Stock for now)
    2016 S5 Cab Black APR Stage 1 (Sold)
    2014 A5 Cab Black APR Stage 1 (Sold)
    2013 S7 White APR Stage 1 (Sold)
    2011 A6 Silver APR Stage 2 (Sold)
    May 23 2016
    Raleigh NC
    Quote Originally Posted by Cruxin View Post
    What are your thoughts of adding the crank pulley?
    Sent from my VS990 using Tapatalk
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    Quote Originally Posted by 3rdBNCC View Post
    Link to the http://www.audizine.com/forum/showth...-Mile-Database C7 C7.5 A6-7 3.0T 1/4 Mile Database
    2012 A7 3.0T Prestige, Ibis white/Nougat/Ash, 20" Sport, ACC, LED, HUD, Ferrada FR2 wheels, AWE Touring exhaust, Adam's Drag II rotors, BlackVue dash cams
    As I've grown older, I've learned that pleasing everyone is impossible,
    but pissing everyone off is a piece of cake
