Results 1 to 4 of 4
    Apr 07 2015
    New york
    installing sport seats in allroad
    My original allroad seats did not have memory option for both the driver and passenger sides, but the nea sport seats I just acquired do. I also have thedoor cards with the memory buttons on them. Unfortunately don't have the wiring. Will they still work as normal if I do not sure up the memory buttons on the door panel?
    Veteran Member Four Rings Racin2redline's Avatar
    Aug 19 2012
    1997 Yamaha razz 50 (sik)
    Long island
    yes the seats will work without memory , you will just have extra connector hanging down under there.
    adding memory I believe it a process requires taking quite a bit of stuff apart
    Sent from my SM-G900P using Tapatalk
    IG: d3bel1o
    Feb 16 2008
    2004 Passat TDI 5spd manual 2005.5 A4 Avant TDI, 2011 X5 35d
    Taylors, SC
    If you just want power and heat, then yes. Like R2R said the effort is quite high and involved to make the memory work if you didn't have it originally.
    For that matter you don't need the memory door cards either
    Apr 07 2015
    New york
    Great thanks for the reply guys. Any diy guides to get the memory working? Just wanna see how involved it will get it has worked the donor car it came from still and can remove the wiring as needed.
