The other night I'm driving about 50km under a bridge and I clutched in and revved it to about 4K RPM I heard a rapid tick then the car shut off I was still rolling I put it in nuterul clutched in and Reyes starting it...it turned over and over but wouldn't start , then I'm still rolling tryed bump starting in second and it just bogged and sort of locked up I come to a complete stop I turn the key off let it sit for 10 minutes go to start it and it just clicks as if the engine is seized, today I pulled everything apart in the front end and turned the crank bolt by hand with s breaker bar the bolt was loose and turned about 3 full rotations before it grabbed Moter spun intill certain spot and locks up engine is seized in thinking there's a valve hitting a piston ?
I've already spent a ton of money trying to bring this thing back to life from lreveious owener was running fine intill 2 days ago when I got a bad misfire and both cam sensor codes and run lean code.
Should I replace the Moter with another one one , rebuild this one or build this one up and or sell the car and take a loss on it? Somebody help.
