    Active Member One Ring trdtyler5591's Avatar
    Aug 21 2016
    Utah
    B6 Trans problems, need help!!!
    So my trans is having some problems... Not throwing any codes, but slips outta gear when i fully turn left or right. Trans fluid is full, could this be due to the trans fluid needing to be changed??? Trans runs fine, other then that.
    Daily: 02' Audi A4 Avant, stock for now
    Wheeler: 96' Jeep ZJ with 3" lift
    Toy: 97' Toyota Soarer with single turbo swap 650hp. Giggity!
    Established Member Two Rings leightonw's Avatar
    Aug 12 2016
    Soldotna, Ak
    Cvt?
    Sent from my SM-G925I using Tapatalk
    Aug 21 2016
    Utah
    Yes, CVT
    Aug 21 2016
    Utah
    Anyone???? CVT trans works fine unless making a full turn and it wants to slip out of gear. Also if i come to a stop real fast, it will slip out of gear. Not pulling any codes, and trans fluid is full. Could this be a result of bad fluid???
    Veteran Member Three Rings chad99's Avatar
    Apr 22 2012
    Fremont, CA
    Is this on your avant? (from sig) I thought all avants were Quattro
