Results 1 to 13 of 13
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Powerflex BLACK upper control arm bushing review
    So i finally pulled the trigger on these bushings, i got them from ECS and it only took 4 days to get them to my door.
    On initial inspection they looked great and were nice and hard. No give what so ever, which is what im looking for obviously.
    I bought a set of new control arm on ebay, it was like $30 for all 4, i didnt care what quality they are since i was gonna press out those bushings anyway.
    Pressing the original bushings out was easy, i actually used a 36mm oil filter socket that fit perfect in the bore and pressed the bushings out very easily.
    Pressing the new ones in were a little more tricky. 3 went in fairly easily, only 1 gave me trouble and i actually pinched off a little of the mushroom hat edge, but it doesnt affect anything.
    It took me 80 minutes to install the new arms. Both of my pinch bolts flew right out with no issues so i got lucky.
    New arms in
    I only took the car out for a quick spin once i finished up with everything at work.
    First impressions are good. Its nice and firm, you can feel it even just going over bumps. The slack i had turning left before (compared to instant right turns) is now gone, so im happy with that. I will report back after a few days for more feedback.
    But overall im very happy and the front end is nice and tight.
    Disclosure, my old bushings were toast
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Been eyeing these for a while now. Subbed for your follow up.
    Oct 24 2015
    Perth, WA
    What is the grease you put on the control arm bushing mate?
    My respray thread
    Dec 01 2007
    San Jose CA
    PowerFlex bushings include a pack of grease.
    Oct 24 2015
    Perth, WA
    Interesting the 034 ones do not. I wonder if I should be adding some?
    My respray thread
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    What is the benefit of the grease if they are closed joints?
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Dec 04 2011
    Kansas City, KS
    I used liquid moly copper anti seize. Copper is recommended by powerflex for poly bushings.
    It keeps them from squeaking
    Active Member Four Rings martin0079's Avatar
    Mar 09 2011
    2001 Audi S4
    Plainfield, CT
    Update
    Dec 04 2011
    Kansas City, KS
    I havent been doing as much driving as id like to give an in depth review.
    But so far, i can feel the road more, which is good. Theres more feedback from my inputs but its not in any way bothersome or harsh.
    Turn in has sharpened, i almost turned off the road doing my favorite on ramp as 50mph (its a pretty tight one) so i have to keep this in mind as its nice and responsive.
    So far no real downsides and i love them.
    I plan on doing the same to the lowers but its a lot more expensive so itll be a while. I found out that superpro actually makes a bushing for the shock fork, so that coupled with both inner powerflex black you can get all three lowers in poly.
    Dec 01 2007
    San Jose CA
    Quote Originally Posted by vvenom800tt View Post
    Theres more feedback from my inputs but its not in any way bothersome or harsh. I found out that superpro actually makes a bushing for the shock fork.
    Always wondered how a firmer bushing swap would play out. Sounds good. Superpro eh? Interesting.
    Dec 04 2011
    Kansas City, KS
    Im excited that theres one for the shock fork
    Established Member Two Rings SimbadCA's Avatar
    May 11 2016
    Audi TT (MK1, 8N) Quattro
    Camarillo CA
    I’m also replacing my LCA bushing. Presently the LCAs have aluminum outer sleeves on the original bushings.
    Do I re-use or replace these sleeves?
    Do the power flex bushings come with the sleeves?
    Thanks
    May 11 2016
    Camarillo CA
    Quote Originally Posted by SimbadCA View Post
    Thanks
    I’ve confirmed with Powerflex USA, that the complete OEM bushing should be removed. The Powerflex solution does not require the use of the outer sleeve...their solution does not require it.
