Are you planning to run a High Flow Cat or stick with stock? Edit:(Missed that you said you already have a HFC, so disregard) Some downpipes will bolt right up to the stock Cat, others won't.
You can't go wrong with JHM from what I have seen, however I use the Unitronic 3" HFC/Downpipe and am very happy with it. Price has gone up a bit lately for the high flow cat and downpipe but I think the price is still much better than most anything else out there.
Performance of the Uni HFC/DP is amazing, I even noticed a difference while still running a stock tune!
Fit is good, however the area where the rear O2 sensor is is very tight and you'll likely need a right angle adapter for the sensor. The downpipe also dips a little low when going under the transmission crossmember. Not sure how this compares to JHM or other 3" downpipes but you lose a bit (Maybe 0.5") of clearance here which is a bit unfortunate.
Only other issue I ran into is that the stock spring loaded exhaust hanger will not bolt directly up to the Uni DP, the DP has an attachment point however a custom bracket has to be made or just left unattached.
It bolted up to my stock rear section of exhaust perfectly with the supplied adapter.
I plan to have an S4 exhaust customized at some point to mate up to the downpipe. The Vband fitting at the end of the downpipe makes fitting a custom exhaust super easy and handy!
