I am a station wagon guy. I love the utility and that a station wagon drives like the car it is. Along with that, I am not a truck owner. When I occasionally have to haul something that is either large or dirty, I prefer to use a small utility trailer. Over the years I have installed a number of hitches on various cars and wagons. It was time for the Allroad to be hitched!!
My hitch of choice has been Curt. They are well made and priced well. My biggest beef with them is that they hang low and are exposed. On my last hitch installation, a 2010 Cadillac CTS wagon, the hitch would often drag when traversing dips. During my search for a hitch for the Allroad, I came across the Ecohitch by Torklift Central. I watched their installation video and loved the fact that the hitch is mostly hidden. In spite of costing nearly double the price of a Curt, I ordered one.
Like the Curt, the hitch was powder coated. The Ecohitch had a textured appearance and appears to be well made. The written instructions were very good with some small photos.
The first instruction says to raise the rear of the vehicle. Having a lift in my garage made that an easy task. (Increasing garage envy would be that my garage has AC, kind of important in August in North Carolina. Seventy-five degrees and little humidity inside the garage.) Having read the instructions ahead of time, I knew that removing the rear wheels would help.
Next up is removing the side panels on each side of the rear cargo area. The passenger side has a 12V outlet that has to be unplugged before you can move the panel completely out of the way.
The back up sensor plug must be undone and the pigtail to the rear bumper cover pushed through the access hole.
To remove the taillights, a large black pin must be unscrewed. Just below that pin is a rubber grommet. Once that grommet is removed, a 10mm hex nut will be found that attaches to the rear bumper.
The taillights are located by two pins on the front edge. Push the taillight to the rear to dis-engage the pins and then remove the electrical connector.
There will be three torx screws in each rear wheel well that attach the inner fender liner to the rear bumper cap. Remove them and a fastener above them that slides off by applying a screwdriver to one side. Underneath the rear bumper cap will be found three more screws that need to be removed.
In the taillight opening will be found a white guide pin. Pry this pin up and then release the guide pin hinge by pushing it towards the center of the car. This releases the bumper cap from the body.
Gently unsnap and remove the rear bumper cap starting at the wheel well corners while working your way towards the center. It comes off fairly easily at this point. Keep in mind the pigtail for the back up sensors on the passenger side.
Remove the spare tire. With it out of the way, remove the plastic liner around the spare tire opening. There are four torx screws on the rear ledge.
Remove the four cargo tie downs and lift off the two side rails. This exposes a bolt on each side that will be used later on.
And the pile is growing.
Remove the 10mm nut that attached the rear exhaust hanger after supporting the mufflers.
