Results 1 to 11 of 11
    Veteran Member Three Rings auditi's Avatar
    Nov 19 2007
    Burlington, WA
    What should be here? Somethings missing, exposed flywheel
    Was doing my first oil change on the USP last night and when changing the filter, I noticed I could see the flywheel! What is missing here?
    -'11 VW Golf 2dr TDI 6-speed manual
    -'59 VW Bus
    -'05 B6 A4 1.8T Quattro USP - Arctic White/Black, 6MT, unk chip, S4 brakes/SS lines, S4 grille, tint, PODI gauge, forge dv, Bose w/ Aux & Sub - sold
    --USP Club Member #212
    -'01.5 B5 A4 1.8TQMS - Silver/Black, tint, M3 lip spoiler, Bose+sub, 1.3 bar custom Neuspeed p-chip, Evo MS CAI, 710n, H&R sports, S4 shocks, short shift, 19mm Neuspeed RSB, poly snub, Blitz dtt w/ red led's - sold
    Jan 10 2015
    United States
    It looks like the crank position sensor, if you look along the firewall the plug for it should be the white one
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Normal. Nothing is missing.
    Nov 19 2007
    Burlington, WA
    Quote Originally Posted by JackOfAllTrades View Post
    If that was missing, I'd think I'd throw a code and wouldn't run right, but all feels good, and no fault codes...
    Weird... It appears that there can be something there since it has mounting holes, but it does appear there hasn't been anything there for some time. If it's normal, I'll leave it, it just doesn't seem right to have the flywheel exposed like that...
    And thanks!
    -'59 VW Bus
    Oct 07 2008
    05’ GLI 1.8T_4motion, 07’ A4 3.2_quattro
    Calgary, AB.
    Transverse cars have this plug that falls out sooner or later... https://www.ecstuning.com/Volkswagen...--1.8T/ES7678/
    Nov 19 2007
    Burlington, WA
    Quote Originally Posted by All_Euro View Post
    A4 isn't even on the list of cars it will fit, nor is that part coming up in a search with A4 as the vehicle type. If it's the same size, I'll get it anyway, rather have that hole plugged...
    -'59 VW Bus
    Oct 07 2008
    Calgary, AB.
    I didn’t see it for the A4 either but, as Old Guy said, I think the opening being unplugged is pretty typical. My Avant has a TIP but I’ve run my VW 6MT with that opening both closed and open with no ill effects.
    Nov 19 2007
    Burlington, WA
    Right on, thanks guys... It's been a few years, so can't remember how my b5 A4 was there...
    -'59 VW Bus
    Veteran Member Three Rings 5ktq's Avatar
    Aug 15 2016
    Western Canada
    I think its a hangover from B3 era, the CIS cars had two crank sensors.
    (or maybe later V6 had the single one on the bell housing instead of in the block, I've never worked on V6).
    Veteran Member Three Rings Toronto5.5's Avatar
    Apr 03 2011
    Normal.
    b6 1.8t is longitudinal so that's why you're not seeing the A4 on the fitment list for that plug.
    Aug 19 2013
    minnesota
    Rinse your mclutchity through them holes. I do it every once in a awhile...
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
